  • masmaz Friend
    #149717
    Hi guis
    selecting the English language, can not display the menu of products, while with the Italian language displays them regularly ….
    All menus and products are translated, before installing the template ja_larix worked well
    thank
    massimo
    1. Immagine-24
    Dear massimo!
    Please kindly submit a ticket, we would like to check this issue in detail
    masmaz Friend
    #337355
    I send a private message 😉
    thank
    Massimo
    masmaz Friend
    #337523
    help me pleasee!!!! :((
    Dear masmaz!
    pls kindly re-send the link to your site, i could not see anything with IP address and link you gave
    masmaz Friend
    #337526
    sorry but maybe you do not understand …. to see my site you must edit the hosts file on your computer by entering the data you’ve written, because the site is not online
    when you made this change then enter into http://www.ilpaguro.info
    regards
    masmaz Friend
    #337531
    Hello I put 2 Attached index.php in Italian and English
    The left menu of products appere when I select the English language ….
    thanks
    Massimo
    masmaz Friend
    #337621
    I carefully analyzed, the index.php file and I got the solution .. stupid as ever ….
    translation of jackets for diving (SGA) in English is BC’s
    and really the ‘ too caused a disruption on the script …… causing the mistake of the products menu…..
    now is magically appeared … :laugh:
    regards
    Massimo
This topic contains 8 replies, has 2 voices, and was last updated by  masmaz 14 years, 9 months ago.
