linebille Friend
linebille
- 2 times in 1 posts
April 11, 2008 at 11:07 am #127472Hi,
the ja newsflash module isn’t displaying my danish characters like æ, ø og å correctly. When the page first loades its all fine, but when displaying the cached newsflash it goes wrong. How can I fix this?:confused:
linebille Friendlinebille
April 11, 2008 at 11:29 am #245207Solved 🙂 Answer was the most obvious one: Added AddDefaultCharset utf-8 to my htaccess
mfcphil Friendmfcphil
- 388 times in 133 posts
April 11, 2008 at 4:06 pm #245234Well done marking as solved
May 17, 2008 at 8:08 pm #249555but i have the same problem whith russian characters.
the solution you offered did not resolve the problem…can somebody help?
May 26, 2008 at 11:06 am #250574Hi I have the same problem with french caract.
Here is my htaccess :
# @version $Id: htaccess.txt 5975 2006-12-11 01:26:33Z robs $
# @package Joomla
# @copyright Copyright (C) 2005 Open Source Matters. All rights reserved.
# @license http://www.gnu.org/copyleft/gpl.html GNU/GPL
# Joomla! is Free Software
# READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE
# The line just below this section: 'Options +FollowSymLinks' may cause problems
# with some server configurations. It is required for use of mod_rewrite, but may already
# be set by your server administrator in a way that dissallows changing it in
# your .htaccess file. If using it causes your server to error out, comment it out (add # to
# beginning of line), reload your site in your browser and test your sef url's. If they work,
# it has been set by your server administrator and you do not need it set here.
# Only use one of the two SEF sections that follow. Lines that can be uncommented
# (and thus used) have only one #. Lines with two #'s should not be uncommented
# In the section that you don't use, all lines should start with #
# For Standard SEF, use the standard SEF section. You can comment out
# all of the RewriteCond lines and reduce your server's load if you
# don't have directories in your root named 'component' or 'content'
# If you are using a 3rd Party SEF or the Core SEF solution
# uncomment all of the lines in the '3rd Party or Core SEF' section
########################################################## SOLVING PROBLEMS WITH COMPONENT URL's that don't work #####
# SPECIAL NOTE FOR SMF USERS WHEN SMF IS INTEGRATED AND BRIDGED
# OR ANY SITUATION WHERE A COMPONENT's URL's AREN't WORKING
# In both the 'Standard SEF', and '3rd Party or Core SEF' sections the line:
# RewriteCond %{REQUEST_URI} ^(/component/option,com) [NC,OR] ##optional - see notes##
# May need to be uncommented. If you are running your Joomla!/Mambo from
# a subdirectory the name of the subdirectory will need to be inserted into this
# line. For example, if your Joomla!/Mambo is in a subdirectory called '/test/',
# change this:
# to this:
# RewriteCond %{REQUEST_URI} ^(/test/component/option,com) [NC,OR] ##optional - see notes##
####################################################### Can be commented out if causes errors, see notes above.
Options +FollowSymLinks#
# mod_rewrite in useRewriteEngine On
# Uncomment following line if your webserver's URL
# is not directly related to physical file paths.
# Update Your Joomla!/MamboDirectory (just / for root)# RewriteBase /
########## Begin - Joomla! core SEF Section
############# Use this section if using ONLY Joomla! core SEF
## ALL (RewriteCond) lines in this section are only required if you actually
## have directories named 'content' or 'component' on your server
## If you do not have directories with these names, comment them out.
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
#RewriteCond %{REQUEST_URI} ^(/component/option,com) [NC,OR] ##optional - see notes##
RewriteCond %{REQUEST_URI} (/|.htm|.php|.html|/[^.]*)$ [NC]
RewriteRule ^(content/|component/) index.php
########## End - Joomla! core SEF Section########## Begin - 3rd Party SEF Section
############# Use this section if you are using a 3rd party (Non Joomla! core) SEF extension - e.g. OpenSEF, 404_SEF, 404SEFx, SEF Advance,etc
#RewriteCond %{REQUEST_URI} (/|.htm|.php|.html|/[^.]*)$ [NC]
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{REQUEST_FILENAME} !-d
#RewriteRule (.*) index.php
########## End - 3rd Party SEF SectionAddDefaultCharset UTF-8
########## Begin - Rewrite rules to block out some common exploits
## If you experience problems on your site block out the operations listed below
## This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to set a mosConfig value through the URL
RewriteCond %{QUERY_STRING} mosConfig_{1,21}(=|%3D)
# Block out any script trying to base64_encode crap to send via URL
RewriteCond %{QUERY_STRING} base64_encode.*(.*)
# Block out any script that includes a <script> tag in URL
RewriteCond %{QUERY_STRING} (<|%3C).*script.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL
RewriteCond %{QUERY_STRING} GLOBALS(=|{0,2})
# Block out any script trying to modify a _REQUEST variable via URL
RewriteCond %{QUERY_STRING} _REQUEST(=|{0,2})
# Send all blocked request to homepage with 403 Forbidden error!
RewriteRule ^(.*)$ index.php [F,L]
########## End - Rewrite rules to block out some common exploitsThank you for your help
May 28, 2008 at 10:30 am #250853I`ll try to do this.
http://www.joomlart.com/forums/topic/odd-charset-problem-with-ja_flashnews/
May be it will helps. -
This topic contains 6 replies, has 4 voices, and was last updated by sergey22 16 years, 7 months ago.
