  • pirinalia Friend
    #169190
    I am trying to set Amazon S3 and I would like your recommendation regarding these two fields that are in profiles.
    Image Compression.: No Yes
    Cache lifetime:
    Thanks you very much for your help.
    Marc
    jooservices Friend
    #418865
    If you turn on those settings, it will help the component work faster. You should decide two choose between file quality and component performance.
    Viet Vu
    pirinalia Friend
    #420250
    Regarding cache lifetime how is it managed? Is it in seconds, days? Besides, do you recommend any setting to boost performance?
    I do not usually change files, mainly images.
    Thanks in advance,
    Marc
    jooservices Friend
    #420343
    Amazon S3 or any kind of CDN should store only files that you never change.
    So if you make sure you will never change these file. Just caching it as lifetime 🙂
    Thank you
    Viet Vu
    pirinalia Friend
    #420374
    Thanks,
    So the value in cache lifetime. which paramaters accept?
    Thanks in advance,
    Marc
    jooservices Friend
    #422144
    Just enter a number ( second ) how long you want to keep your cache .
    For better tut you can watch our video: http://www.youtube.com/watch?v=dtknH2ljq5Q&feature=player_embedded
    Thank you
    Viet Vu
This topic contains 6 replies, has 2 voices, and was last updated by  jooservices 13 years, 2 months ago.
