mjmo Friend
mjmo
- February 2012
- 2 times in 1 posts
August 22, 2012 at 9:33 am #464951I just found that the Twitter module is currently also not working on your demo page. (See picture attached.) So maybe there’s another reason for it…
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
August 22, 2012 at 10:10 am #464966HI Mjmo
When you visit our demo, may be there are more than 150 visitor. Hence,Twitter did not display.Regards,
mjmo Friendmjmo
- February 2012
August 22, 2012 at 12:38 pm #464987<em>@HeR0 335422 wrote:</em><blockquote>HI Mjmo
When you visit our demo, may be there are more than 150 visitor. Hence,Twitter did not display.Regards,</blockquote>
Hi HeR0,
maybe that’s true for your demo page but I can’t be for my site as it is not yet a live site. Nobody knows about the link and it is not listed in any search engine.
I have established another installation of JA Zite for testing purposes on another subdomain and the problem is just the same there. Since this site is in offline mode most of the time I’m pretty sure that I’m the only visitor to it.
HeR0 FriendHeR0
- August 2011
August 23, 2012 at 2:02 am #465039Hi Mjmo
To solve this problem, you can use cache function, please enable cache function in template setting.Regards,
mjmo Friendmjmo
- February 2012
August 23, 2012 at 1:09 pm #465122Hi HeR0
I’ve now enabled the Joomla cache and the cache of the JA Twitter Module. Furthermore I’ve turned off the development mode.
Unfortunately, the Twitter module still refuses to show my tweets. Maybe you could have another look at it?
Best regards
mjmo
mjmo Friendmjmo
- February 2012
August 27, 2012 at 9:20 pm #465525Hi HeR0
it seems as if now the Twitter module does work as it is supposed to. However, I can’t make it to show only one tweet. It only works if the number of tweets is set to 5. If I try to set the number of tweets to any other number it refuses to work.
HeR0 FriendHeR0
- August 2011
August 28, 2012 at 2:52 am #465546Hi Mjmo
You can set to 1 and clean all cache for applying the changes.Regards,
mjmo Friendmjmo
- February 2012
September 1, 2012 at 10:17 am #465963Hi HeR0
the module worked for two days before it stopped doing so again. At least that’s an improvement over not working at all. 😉
For testing purposes, I’ve now download several other Twitter display modules from the Joomla Extensions Directory and installed them on my JA Zite test system. Surprisingly every single one of them works like a charm, except for the JA Twitter module.
In conclusion that means that there can’t possibly be an issue with the Twitter API. There must be another reason that causes my problems which I assume to be located anywhere in the JA Twitter Module’s source code.
I would greatly appreciate it if you could have another look at the issue as I really want to use the JA Twitter module on my site.
After all, I paid for the module, so I think I can expect it to work.
Best regards
mjmo
HeR0 FriendHeR0
- August 2011
September 4, 2012 at 3:53 am #466045Hi Mjmo
Thank you. I reported to Dev team check and upgrade Twitter API. You can follow at http://pm.joomlart.com/browse/JAECMODJATWIJIVI-30Regards,
mjmo Friendmjmo
- February 2012
September 4, 2012 at 8:57 pm #466134Hi HeR0
Thanks for your help. Unfortunately I can’t access your link with my login data. I’m sure that you will inform me as soon as there’s something new to report about the issue.
Kind regards
mjmo
HeR0 FriendHeR0
- August 2011
September 5, 2012 at 2:38 am #466155Hi Mjmo
The issue is published, now you can follow it.Regards,
<em>@mjmo 336993 wrote:</em><blockquote>Hi HeR0Thanks for your help. Unfortunately I can’t access your link with my login data. I’m sure that you will inform me as soon as there’s something new to report about the issue.
Kind regards
mjmo</blockquote>
mjmo Friendmjmo
- February 2012
September 13, 2012 at 8:57 am #466913Hi HeR0,
is there anything new to report on my issue? When I look at the dev team report nothing has happened since you brought the issue to the table.
mjmo
HeR0 FriendHeR0
- August 2011
September 26, 2012 at 9:29 am #468195Hi Mjmo
I am sorry to say that there is no info regarding your issue as we have full capacity.I will keep you updated if there is any info.
Regards,
<em>@mjmo 338042 wrote:</em><blockquote>Hi HeR0,is there anything new to report on my issue? When I look at the dev team report nothing has happened since you brought the issue to the table.
mjmo</blockquote>
AuthorPostsThis topic contains 28 replies, has 2 voices, and was last updated by HeR0 12 years, 3 months ago.
