  • dogtags Friend
    #126758
    There is a space between the bottom of the top horizontal nav and the top of the main body.
    How can this space be reduced?
    I’d like to use the CSS menu but reduce that horizontal white spacing
    Thanks 🙂
    kade119 Friend
    #242621
    check in your menu css
    #ja-subnav (line 761)
    display: block;
    font-size: 92%;
    border-bottom-width: 1px;
    border-bottom-style: solid;
    border-bottom-color: #e7e8e6;
    height: 28px;
    believe its that… use firefox web developer toolbar and click css style information.. will help alot
    Menalto Friend
    #242625
    Or you can open up the template.css on line 574
    margin: 25px 0;
    padding:0;
    And change what i marked in red to the margin you want.
    Ex: margin: 10px 0 25px 0, this will make the space to top 15px smaller than it is now.
    dogtags Friend
    #242695
    Thanks, I’ll try both and see how it goes, much appreciate your input 🙂
This topic contains 4 replies, has 3 voices, and was last updated by  dogtags 16 years, 8 months ago.
