amahadevan Friend
amahadevan
- December 2009
February 1, 2013 at 1:22 pm #184586Just downloaded your JA Onepage template and after setting it up,i checked the site in a responsive tool and found some error.
How can i just reduce the space that i have marked in the screenshot.
Can anybody just help me out??? #urgent.
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
February 1, 2013 at 1:56 pm #482016That is not an error, but by design. You can adjust that space with a simple css adjustment
Open templates/ja_onepage/css/template-responsive.min.css at line 291
.hero-unit .container {
padding-top: 120px;}
and adjust the 120px to your requirements. That will only affect the mobile versions.
amahadevan Friendamahadevan
- December 2009
February 4, 2013 at 5:30 am #482260Thanks for your reply.
It is affecting the mobile devices as well as in all other devices also.(Ipad and Desktop etc)
The text written there is going under the header part.:((Can you please slove this out????
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
February 5, 2013 at 9:41 am #482483Hi Amahadevan,
Phill is right, you can also adjust that value in templatesja_onepagelessstyle-responsive.less then Compile CSS in template setting http://prntscr.com/rmsb4
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by HeR0 11 years, 10 months ago.
Space issue in JA Onepage while viewed in small devices.
