  • judemac Friend
    #133859
    I am having a problem with the spacing around my images. I have set the vertical and horizontal space around the image to 5 with a border of 1 and in Explorer the spacing is perfect, but in Firefox there is no space at all. The text is rammed up against the image and looks very bad.
    Does anybody have a solution to this – the template I am using is JA Antares. Another problem I came across is with the page width, if set at it’s narrowest then you can’t use the suckerfish menu as it disappears when you go to click on a link, most annoying!
    Cheers,
    judemac
    questbg Friend
    #273042
    Hi judemac
    Not sure what template you’re using, but I’m using Telline II. I also had this problem which I fixed by applying ‘caption’ style to all images.
    I gave instructions in this thread:
    http://www.joomlart.com/forums/topic/template-module-update-doesnt-work/#post-273038
    Which worked for this user too!
    May be worth a try?
    Good Luck
    Chris
    judemac Friend
    #273075
    Thanks that worked a treat!
    Still learning my way around Joomla, coming from a Dreamweaver background…….. soooo much to learn!
    Judemac
    questbg Friend
    #273210
    Hi judemac
    <em>@judemac 82999 wrote:</em><blockquote>Thanks that worked a treat!
    </blockquote>
    Glad to hear it! However, I think this is a problem with IE7 rather than anything else! Let’s hope they fix this in IE8 to save us having to make stupid workrounds with every image we insert!!
    <em>@judemac 82999 wrote:</em><blockquote>Still learning my way around Joomla, coming from a Dreamweaver background…….. soooo much to learn!
    </blockquote>
    Don’t worry, I’m only a few months in front of you! I’ve always used Freeway on a Mac so to get into CMS, Joomla, SQL, etc., has been quite a steep learning curve.
    Plus, I’m still learning!
    Good luck with your site
    Chris
This topic contains 4 replies, has 2 voices, and was last updated by  questbg 16 years, 2 months ago.
