November 17, 2006 at 10:25 pm #117689
Hi, I have a slight problem with the spacing on the menus with the collapsed menus module installed. Notice the large space between the “We have 1 member online” and the bottom on the menu. The thing is, when the menu is collapsed and reopened, and large space goes away. The images are the correct sizes, and the settings in Joomla are based on your read me post. And here is the code in the css file. I’d appreciate the help. Thanks!
div.module h3 {
margin: 0 0 15px;
font-size: 1em;
}div.module {
margin-bottom: 15px;
padding: 0;
float: left;
width: 100%;
background: url(../images/box-br.gif) no-repeat bottom right;
}div.module div {
padding: 0;
background: url(../images/box-bl.gif) no-repeat bottom left;
}div.module div div {
padding: 0;
background: url(../images/box-tr.gif) no-repeat top right;
}div.module div div div {
padding: 9px 15px 20px;
background: url(../images/box-tl.gif) no-repeat top left;
}div.module div div div div {
margin: 0;
padding: 0;
background: none;
November 17, 2006 at 10:40 pm #211778I just wanted to point out that this happens on all menus, and not just the example I showed you. Thanks.
ha le-viet Developerha le-viet
- April 2006
- 5 times in 1 posts
November 18, 2006 at 2:36 am #211781Hi drumbrad1,
Did you try the expand offset parameter of JA Collapsed Modules? Put some value around -30 there and you’ll see the changes.
Regards,
Ha Le-Viet.November 18, 2006 at 3:02 am #211782Nope. Still the same problem. I played with different numbers and still have the same problem. It’s weird, because when the page is loading, the spacing is momentarily correct, but when the page fully loads, the menus expand a little and the large gap happens.
- April 2006
November 18, 2006 at 4:18 am #211785Hi drumbrad1,
Please update the Collapsed Modules from our download section and try to reinstall the module. There was a minor bug and it had been fixed.
Regards,
Ha Le-Viet.November 18, 2006 at 2:46 pm #211817Problem solved. Thank you.
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 2 voices, and was last updated by drumbrad1 18 years, 1 month ago.
Spacing problem with collapsed menus
