  • imasdtecno Friend
    #199951
    Hi. In some screens resolutions the margins and spacings looks well and equal (1366 x 768), but whith higher resolutions (1920 x 1080) the margins of text and images are not equal causing bad display issues.
    For example, in this pic i have a 1366 x 768 and all looks well.
    In this pic I have a 1920 x 1080 resolution and the margin near text is increased, but the margin of the image no. The margins need to be equal in all situations.
    Any fix for this issue? Thanks.
    1. C2
    2. C1
    Could you post your site’s URL here so that I can have a look?
    imasdtecno Friend
    #543445
    This is the URL http://www.imasdtecnologia.com/test14/
    You need a user and password to view the page. I sended an MP to you.
    Thanks a lot!
    You can try using media jQuery to add specific style for specific screen resolution. Here is my workaround:
    – Create a new css file called custom.css in this path: /templates/ja_appolio/css
    – Add this css rule:
    @media screen and (min-width: 1920px){
    .custom.onepage-5.onepage-image .col-md-6.col-sm-6.col-xs-12.img-left img {
    margin-left: 230px;
    and change the above value to suit your need.
    imasdtecno Friend
    #543663
    I made the changes in custom.css but I can not see any changes in the website. I cleared navigator caches.
    This is my custom.css placed in /public_html/test14/templates/ja_appolio/css
    margin-left: 230px;
    This is the HTML code of the module that shows the image:
    <div class="clearfix">
    <div class="col-md-6 col-sm-6 col-xs-12 img-left"><a href="http://www.click-arm.com"><img style="margin-bottom: 0px; margin-left: 30px;" src="images/5.png" alt="" width="593" height="333" /></a></div>
    <div class="col-md-6 col-sm-6 col-xs-12 pull-right" style="text-align: justify;">
    <a href="http://www.click-arm.com" style="text-decoration: none;"><h1>Click ARM. Construya su propia experiencia</h1></a>
    Con Click ARM es usted, y no el fabricante, quien elige las características y la vida útil de su dispositivo, minimizando la huella ecológica y desterrando la obsolescencia programada.
    <p> </p>
    Click ARM es la primera tablet modular con una Placa Base Matriz a la que le puede añadir, quitar o cambiar, la memoria RAM, la memoria de almacenamiento o cualquiera de los módulos que la componen. <a href="http://www.click-arm.com">Saber más...</a></div>
    </div>
    This is the custom class subfix of the module:
    onepage-5 onepage-image
    imasdtecno Friend
    #543759
    Ok. Problem solved. There was a mistake in the class name.
    Media query now works great except in firefox 31 for linux, in other explorers works fine. this is normal?
    Thanks.
This topic contains 6 replies, has 2 voices, and was last updated by  imasdtecno 10 years, 5 months ago.
