  • prgbono Friend
    #187895
    Firstly I am introducing myself. My name is Paco and I’m a new member.
    Here’s my question,
    Thoug I have looked for it, I haven’t found the way to install spanish language on a joomla 2.5 with the ja_ores template installed. Either for the site nor the control panel.
    As you can see in the attachment, no Spanish posibility!
    Anybody has done this?
    Any reply appreciated. Thanks!
    1. ja_ores-forum
    You need to download and install the spanish language from HERE after installed you need to set the Spanish language as default for Front end and back end
    prgbono Friend
    #494450
    Solved!!
    I didn’t know I had to install it like an extension, I thougt it should appear in the list!
    Thanks a lot pavit!!
This topic contains 3 replies, has 2 voices, and was last updated by  prgbono 11 years, 6 months ago.
