  • K Schneider Friend
    #203912
    When testing my site in gtmetrix.com it is giving the following message:
    The following image(s) are missing width and/or height attributes.
    What can I do to solve this.
    Best regards
    Ocean
    Ninja Lead Moderator
    #560007
    Please remember that on the responsive websites the width and height attributes are useless and can only cause more problem than help. That’s why we didn’t add this feature to this module.
    K Schneider Friend
    #560036
    Yes I know, is’t there any trick with java or jquery to add the width/height to the image so that google and others see it als a perfect build website with maximum speed performance?
    #560121
    Some ways below will help your site is good performance
    + Remove unnecessary White Space in HTML
    + Minify Javascript and CSS
    + Reduce requests by combining HTML, CSS, and Javascript
    + Optimize all your images – Most if not all should be at least below 10kb
    – Crop the white space using Photoshop
    – Use PNG8 Files or GIF files rather than Jpegs and don’t use transparency
    – Make images the size you want rather than resizing them in the editor
    + Uninstall any components/modules/plugins that you don’t actually use
    + Use Gzip Compression to Reduce HTML Size
    + Enable Caching as much as possible (page caching, view caching, module caching)
This topic contains 4 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 10 months ago.
