  • ardexus Friend
    #151909
    I’m trying to use the split menu technique in a JA Ores template site.
    So matter how I set my main menu module, it still shows all the levels. I want it to only show 2 levels: the first items and one level down.
    I’ve tried setting the mod_mainmenu Start and End Level to 0,0 or 0, 1 or 1, 1, etc, but no matter what, all menu item levels keep showing.
    Always Show Sub-Menu Items is set to No
    I’ve tried setting Maximum Menu Depth to 0, 1, 2, etc. but it doesn’t change anything.
    Expand Menu in Other Parameters is set to No
    I’ve tried all Menu Styles:
    List, legacy Horizontal, Legacy Vertical, Legacy flat list, and nothing makes a difference.
    How can I properly use the split menu technique in JA Ores??
    ardexus Friend
    #347478
    Nevermind. I found it.
    There is a menu over-ride setting in the Template Manager screen for JA Ores (and presumable all JA templates). It was set to:
    Menu Start Level = 0
    and Menu End Level = -1 (infinite)
    Setting it to 0 and 1 has solved my problem.
This topic contains 2 replies, has 1 voice, and was last updated by  ardexus 14 years, 6 months ago.
