I’ve read through the documentation, and the setup for 1.0x users. Including looking at the “ja_vars_1.0x.php” file. I installed the “ja_helio_quickstart_v1.0_1.0.x” files and setup from there. I also have the sh404SEF module installed.
But, I cannot understand how the default “Split Menu” works (the one that is in position A at the top of the page – which I cannot publish/unpublish). I can’t find any documentation on this menu ?
If I add a new menu link item to the main menu (which I assume the menu in position A, at the top of the page uses), when I click on the default installed links the top menu remains with a highlighted menu item showing which topic I am in, but with my added link no item is highlighted in the above menu. So for me the actual link works but the highlighting doesn’t, and I have no idea how to build a split menu with this sytem.
How can I replace whatever menu lives in position A with a menu of my choice (extended menu for example – which I know how to use) ?
Any pointers greatly received. Thanks,
Dave
