  • toonetcreation Friend
    #1025675
    I have a problem with Ja Alumni template. I have published 2 modules in spotlight-tp-1 and spotlight-tp-2 positions but they are not displayed.
    Do you know why?
    Thanks Laurent
    Pankaj Sharma Moderator
    #1025835
    spotlight t1,2 are custom positions.
    You have to create JA ACM module with spotlight style to add the position on the page.
    See this: http://prntscr.com/eovxl9
    And this: http://prntscr.com/eovxux
    After creating the modules as in my screenshots you can published the module on these positions.
    #1025925
    ok works fine thank you 😉
    I think could be helpful to add this on documentation no ?
    Laurent
    #1025931
    Yes, I just shared the Feedback to concern department for the improvement.
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 7 months ago.
