  • leszeks Friend
    #123112
    I instaled 3 times.
    I chacked for all sites.
    Pictures work o main site and other. But I couldn’t take them in one line like on demo (JA ROCHEA).
    Text and Ajax dosen’t work on front page., but only on others (all 3 modules can’t be on one line like on the demo site.
    So, I measured all dimmensions on the demo – there are the same as on my project.
    I would like to add that I change dimmension of all images to the same parameter like on demo site.
    Please see on: http://www.mieszkanko.com.pl
    What I should to do ?
    mfcphil Friend
    #230727
    Are you sure you have them in user position 1, 2 and 5 and what size are your images?
    leszeks Friend
    #230728
    You are right ! One of them was dubled in the user5 posiition – I think it was happened durring coping the module and I forgoten about this case.
    But it is interesting what width should have pictures – could you please recomend me the better dimmension ?
    Thanks for your advice about the possition mistake I made ;o)
    mfcphil Friend
    #230729
    think if I remember correctly when I used positions 1, 2 and 5 I had images at 160 by 200 but I have my boxes in the RIGHT section now if you want to put the there reduce again to 140 by 160
    ra2906 Friend
    #230754
    hi
    i have fast the same problem.
    at my homepage http://www.amafo.de
    doesnt work the rollovertext…
    what ist wrong ?
    can everyone help me ?
    thanks ralf
    swemmel Friend
    #230758
    ra2906;29285hi
    what ist wrong ?
    thanks ralf
    Ralf,
    I did send you an email. Send me (by PM or mail) an admin user/password and I will see what I can do for you.
    Kind Regards,
    Peter
This topic contains 6 replies, has 4 voices, and was last updated by  swemmel 17 years, 2 months ago.
