  • annekek Friend
    #141931
    Hi, I have problems in IE with the spotlight modules in JA Drimia. In Firefox and Opera everything is ok. The spotlight modules on frontpage are not showing up.
    http://www.lukasschooldrachten.nl
    Regards, Anneke
    mfcphil Friend
    #307953
    just add the compatability code and it will display your spotlights 😉
    annekek Friend
    #307954
    Could you please explain? What code, where to find it an where to place it :confused::)
    Thanks, Anneke
    mfcphil Friend
    #307957
    Until you get a fix from JA
    go to your admin and find your index.php file
    add the following code into the first line of your <head> of that file
    <meta http-equiv=”X-UA-Compatible” content=”IE=7″ />
    jcpy Friend
    #311454
    Thanks for you help. It work!!
This topic contains 5 replies, has 3 voices, and was last updated by  jcpy 15 years, 4 months ago.
