June 3, 2017 at 3:53 pm #1039260
I have a problem with Spotlight content block
The top two positions are shown next to each other instead of one.
Squares are not displayed responsive.
How can I solve this problem?Also, the menu does not work properly – menu button from Collapse navigation for small screens
Sincerely i do not know when these functions are working properly; i have made frequent updates from Joonlart and have not checked every time. I use the site very much on my desktop. Today I noticed these issues on the smartphone.
http://www.pomicultor.roThank you in advance!
Best regards!
June 3, 2017 at 7:06 pm #1039277PROBLEM IS SOLVED.
BACK-UP SAVED ME!!! (8 DAYS)
THANKS EVERYONE!Pankaj Sharma ModeratorPankaj Sharma
June 4, 2017 at 9:04 am #1039333Hi
Glad the issue is solved, please take backup of site before update Joomla.
OR try the update on a test site, if you will get this issue again, kindly write back to us with a URL and screenshot.
I will check it.Regards
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 2 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 7 months ago.
Spotlight responsive problem
