Viewing 15 posts - 1 through 15 (of 16 total)
  • Saguaros Moderator
    #1065542
    I don’t see the 4th element now, could you share the credentials of your site?
    7of9 Friend
    #1065543
    Yes, I had to remove 2 elements. The 4th is now 3rd, called "satisfaction rating".
    You already have the credentials to this site and ftp access from another thread.
    7of9 Friend
    #1065860
    Any news on that one?
    7of9 Friend
    #1066130
    @saguaros any news on this one please?
    7of9 Friend
    #1066409
    Anybody?
    I will pass to the team if they can improve this feature or not. Kindly wait.
    7of9 Friend
    #1073679
    @saguaros any news on this? It’s been over a month now. I really need this. At least could you please tell me which file I should check?
    7of9 Friend
    #1073681
    I think I found where and what I need to change, but I still cannot make it right: /templates/ja_rent/acm/statistics/js/script.js
    function formatter(value, settings) { // Add the following line before return value.toFixed(settings.decimals); if (value != Math.floor(value)) { return value.toFixed(1); } return value.toFixed(settings.decimals); }
    However, it seems to add .0 to integer numbers as well, so it shows 98.2 correctly, but also shows 12023 as 12023.0
    Could you please help me out a little, because I really need to deliver this?
    Thank you in advance.
    • This reply was modified 7 years, 1 month ago by  7of9.
    Let me check and see if I can help.
    7of9 Friend
    #1074104
    @saguaros thank you, waiting for you to check.
    You can download and copy attached file to replace this file: root/templates/ja_rent/acm/statistics/tmpl/style-1.php (Remember to backup first)
    1. style-1.php_-1.zip
    7of9 Friend
    #1074318
    Hi @saguaros ,
    It does not seem to be working. What are the changes you made?
    I added the additional attribute for stats-item-counter div tag, you can share the URL, Admin + FTP account of your site, I will check for you.
    7of9 Friend
    #1074579
    It due to your custom in JS file, I commented it and it works now.
    Kindly check.
This topic contains 16 replies, has 2 voices, and was last updated by  7of9 7 years ago.
The topic ‘Stat's module element questions.’ is closed to new replies.
