spiralgr Friend
spiralgr
- May 2015
- 4 times in 1 posts
May 28, 2015 at 6:14 am #206700Hello i have made the changes you suggest for the sticky menu and works perfectly in blog template layout but not in home template layout.
Do i miss something? Any suggestions?
I can’t send you a link because my site is at localhostSaguaros ModeratorSaguaros
May 28, 2015 at 4:39 pm #572174You can post your site’s url here and tell me the steps you already proceeded.
I will check it for you.
spiralgr Friendspiralgr
- May 2015
May 29, 2015 at 8:54 pm #572350I followed the steps mentioned here http://www.joomlart.com/documentation/joomla-templates/ja-hotel-template/how-to#sticky-menu
In my website i use two layouts, home and blog. Sticky menu works in blog layout but not in home. Again my website is in localhost so i can’t provide a link.
Home layout http://static.joomlart.com/images/userguide/ja_templates/hotel/home-layout-1.jpg
Blog layout http://static.joomlart.com/images/userguide/ja_templates/hotel/blog-layout.jpgSaguaros ModeratorSaguaros
June 3, 2015 at 11:23 am #572715It’s really weird as I also tried with above tip but it worked properly.
Pls try to clean all the caches on your browser. In case that problem still persists, you can put your site online and PM me your site’s login info, I will check it for you.
June 3, 2015 at 11:23 am #737750It’s really weird as I also tried with above tip but it worked properly.
- May 2015
June 3, 2015 at 8:22 pm #572795I will try this and come back with the results
- May 2015
June 6, 2015 at 3:31 pm #573135No the problem remains
June 9, 2015 at 2:28 am #573378Is everthing ok now? as I’ve not received any message from you.
Let me know if you still need help on this.
- May 2015
June 10, 2015 at 7:27 pm #573629yes the problem remains, and i do not see why. Any ideas? Something i can try now at localhost? Or else i must wait for the website to be ready and get it online so you can take a look
- May 2015
July 6, 2015 at 8:59 pm #576536i have send you log in information in private message
- May 2015
July 6, 2015 at 8:59 pm #642849i have send you log in information in private message
- May 2015
July 6, 2015 at 8:59 pm #741506i have send you log in information in private message
This topic contains 19 replies, has 2 voices, and was last updated by spiralgr 9 years, 6 months ago.
