  • artaddicted Friend
    #133842
    Just noticed that if I use a larger picture and a Sticky Note on the same page there appears to be formating problems.
    • The Sticky Note container expands the total width of the section
    • The Picture lays over the Sticky Note Box
    • The contents (Type) within the Sticky Note box is adjusted for the Picture and its padding
    I think the Sticky Note box should also be adjusted to stop at the Picture padding. Is there a fix for this?
    Here is a live link to the site showing this issue: SITE
    I have changed most of the other imaged and replaced with ones that fit. However, I would like to see a fix for this issue.
    1. Sticky-Note-Issue
    Menalto Friend
    #273019
    One thing you can try is to add a specific width to the stickynote in the css file, search for this:
    p.stickynote
    and you can add width: 60%; to it to see if that helps you out, if you need to use many different you can copy the p.stickynote css and name it p.stickynote-1 and add a different width to it
    mfcphil Friend
    #273020
    looks more like an image allignment or size issue rather than a problem with you stickynote…
    Why not add a few more lines of text to overcome this problem which will also give a more balanced look to your page…making the main text area line up with the modules in the left
    Menalto Friend
    #273023
    OR It can help to set width and height of the image?
    artaddicted Friend
    #273175
    I have already made some changes to other pages that include:
    1. Changing the dimensions of the image to fit the available area
    2. Changing the image to a horozional image
    3. Adding additional text to the content area
    4. Not using the Sticky Note
    I was just hoping that there would be a way to get the Sticky Note pad to adjust to the image border (Hor: 15px, Vir: 10px). I will select one or more of the above to make things look more appropriate.
    Currently, I fixed all of the images width to 250px with the hight adjusting.
    <blockquote>if you need to use many different you can copy the p.stickynote css and name it p.stickynote-1 and add a different width to it
    </blockquote>
    This would be the best option for me, if there is no way to automatically adjust to the Sticky Note pad padding, and I was not willing to make any of the above adjustments.
    Thank you all for your input. If there is a corrective measure to make the Sticky Note pad adjust automatically, I would be happy to try to get it to work.
This topic contains 5 replies, has 3 voices, and was last updated by  artaddicted 16 years, 2 months ago.
