July 28, 2017 at 2:14 am #1052066Hi,
Could you create a test site with latest version of template and J3.7.4 and share me the login info (URL, Admin + FTP account) ? I will take a look.
December 4, 2017 at 1:34 pm #1078698Any solution? I need to update the Joomlar version to 3.7, but I need this theme to work fine too.
December 5, 2017 at 2:25 am #1079036Hi,
JA Magz should be compatible with J3.7 already, pls take a full backup of your site before updating. If there is any issue with template, share us the credentials of your site so we can check and help you out.
January 18, 2018 at 9:29 am #1087480This reply has been marked as private.Saguaros Moderator
January 18, 2018 at 9:37 am #1087488Hi Isabel,
That issue relates to the menu assignment only, at this moment, it seems that the articles on homepage of your site are not assigned to any menu item so that it keeps displaying on the homepage.
You can try creating a new menu item (or use existing one) and assign these articles (or category these articles belong to) to that menu item. I will work then.
January 20, 2018 at 6:06 pm #1087827This reply has been marked as private.Saguaros Moderator
January 22, 2018 at 9:53 am #1088027Hi,
I guess there is something wrong with the upgrade process, could you try to upgrade again in local/test development environment?
January 22, 2018 at 12:09 pm #1088054This reply has been marked as private.Saguaros Moderator
January 24, 2018 at 9:15 am #1088304Hi,
I see the same in test site.
January 24, 2018 at 9:38 am #1088308???..
There is also still the even bigger problem: the missing tabs!
Please understand that I cannot edit articles, users,… because of the missing tabs. Neither do the "save / save as copy / etc." buttons work.you see that in the test site?
This reply was modified 7 years ago by
isabelgica.
January 25, 2018 at 8:48 am #1088455Yes, I see the same in the test site.
I think there may be something wrong with the upgrade of Joomla, could you try to restore the old version and proceed upgrading to Joomla 3.8 again?
January 25, 2018 at 9:03 am #1088461I told you already this was no upgrade but a new, fresh install with J. v.3.8.3.
Nothing went wrong on the test site. There the tabs are NOT missing (so very strange that you apparently see the same in the test site, because it is NOT the same).Be it as it is…. it is clearly that you are not able or not willing to take this serious and assist.
I’ve explained the problem several times, but am losing more time here trying to get assistance than building the wole thing again (as before, when there was no assistance/help/solution either).
So you can close this unsolved threat.
have a nice day.
January 25, 2018 at 9:27 am #1088471Hi,
I’m mentioning the redirection issue when clicking an article, for the missing tabs issue, where I can login from frontend of your site (sorry as I’m not familiar with your native language), I will check for you.
January 25, 2018 at 9:43 am #1088477Hi Saguaros,
as said, never mind and you can close this threat.
I already started building everything anew because I cannot afford to lose more time.thanks &rgds,
Isabel -
This topic contains 16 replies, has 3 voices, and was last updated by isabelgica 7 years ago.
The topic ‘Still problems with JA Magz (v.1.1.3) and J! v.3.7.4.’ is closed to new replies.
