test melih
 melih
  • final Friend
    #203357
    Is there any change that we can get rid off this message:
    Unexpected error. Please refresh the page try again later.
    Memory limit is 256M
    Tried compiling active theme only
    php 5.4
    J. 3.4
    T3-framework 2.4.1
    template “dezekeer” cloned from t3-bs3-blank
    I have to run a few sites in developer mode because i can not compile the less files.
    I don’t know what compilers there are but I played arround with gavern framework and that less to css compiler is lightning fast whithout errors on the same hosting enviroiment.
    I really love the T3-Framework. I appriciated the effort you put in a lot of documentation and tutorials.
    I hope we can get rid of this problem
    Friendly greetings
    Perry
    Manos Moderator
    #557752
    I wasn’t able to spot the message on your site, can you please tell me where I can see the problem ?
    arthurjohnston Friend
    #557754
    @final
    I experienced a similar problem and determined there are three situations where a compile of Less cannot complete.
    (1) Less requires 128megabytes of memory to compile. If memory is not sufficient a compile will not complete;
    (2) An improper modification of the Less files; and
    (3) A version mis-match between T3 Framework and T3 Framework Package and/or your template
    (4) Joomla file permissions are incorrect.
    I hope this helps.
    final Friend
    #557755
    You can see the problem when you try to compile Less to Css the “dezekeer” template.
    Ninja Lead Moderator
    #557805
    @final: Did you check with suggestion from @arthurjohnston ?
    jooservices Friend
    #557815
    Hi there,
    I have tried to inspect your live site and got this ajax response.
    <!DOCTYPE HTML PUBLIC “-//IETF//DTD HTML 2.0//EN”>
    <HTML><HEAD>
    <TITLE>500 Internal Server Error</TITLE>
    </HEAD><BODY>
    <H1>Internal Server Error</H1>
    The server encountered an internal error or misconfiguration and was unable to complete your request
    <HR>
    <I>www.dezekeer.nl</I>
    </BODY></HTML>
    Look likes not memory_limit issue. And would be less issue.
    Thank you,
    Viet Vu
    final Friend
    #558072
    <em>@arthurjohnston 456406 wrote:</em><blockquote>@final
    <<< I have 256M according to the php information. As stated in my opening message>>>
    <<< That is why I put a request on this forum!! Even the brand new latest version of the T3-Framework 2.4.1 and the untouched latest version of the t3-bs3-blank template is not working!! I don’t have the knowledge to determine what could be the cause.>>>
    <<<All folders are set to 755 all files to 644>>>
    I hope this helps.</blockquote>
    So the answer is YES I checked all that!
    Hope anyone has the knowledge to help me and very much others with the less to css compiling problem.
    Thanks for your attention.
    Perry
    jooservices Friend
    #558097
    hi there,
    Please provide your site backend & cpanel access for checking.
    Thank you,
    Viet Vu
    jooservices Friend
    #558105
    Hi there,
    I have tried to install Akeeba on your site but also can’t.
    Look like this server is very low of resource. I can’t touch much thing on this. Please update with CPanel than i can try another way.
    It mostly like server issues.
    I also verified with my local server ( Ubuntu ) – Joomla! 3.3.6 & Latest T3 + Blank template.
    Everything working fine.
    Thank you,
    Viet Vu
    1. 2014-12-10_12-10-47
    final Friend
    #558145
    Thank You Viet Vu,
    I send login and ftp info to Arthur Johnston.
    I am on a commercial Shared Hosting webhosting. http://www.versio.nl
    There is a good helpdesk. But I don’t know what to ask them concerning this problem. I understood it is no option to install CPanel on shared hosting.
    Your help is very appreciated!!
    gronter Developer
    #558184
    Hi!
    1.- Initially I had Joomla 3.3.6 installed, 128M memory limit, Purity III template and T3-framework 2.4.1.
    2.- I had the same problem when I tried to compile LESS to CSS: “Unexpected error. Please refresh the page try again later.”
    3.- My solution has been to uninstall T3-framework 2.4.1 plugin and to install again T3-framework 2.1.4. Now for the moment everything works fine and it compiles successfully:).
    I hope it helps!
    austenn01 Friend
    #561135
    This is not a long term solution. You need to speak to your host.
    May I suggest you change hosts to Siteground. They specialise in joomla hosting and their support and very well versed in joomla as well. Also, they have the fastest joomla hosting I have every found.
This topic contains 12 replies, has 7 voices, and was last updated by  austenn01 9 years, 11 months ago.
