  • tekdinet Friend
    #206873
    I am having a weird problem, where I cant see any topics to assign to the module. When I click the select topic button, the popup is completely blank even though I have created a topic.
    Secondly, I am also having this problem with the article. The same issue happens whenever I try to assign a particular topic to an article from the article settings (General tab).
    Please check the attached screenshots
    1. ja-acm-no-article-art-menu
    2. ja-acm-no-article
    Ninja Lead Moderator
    #572930
    I log into back-end of your site and check the ACM module but I could not get the problem as you mentioned above
    Please clarify the steps so that I can replicate the issue and help you out.
    1. Screen-Shot-2015-06-04-at-17.49.22
    tekdinet Friend
    #573050
    <em>@Ninja Lead 476527 wrote:</em><blockquote>I log into back-end of your site and check the ACM module but I could not get the problem as you mentioned above
    Please clarify the steps so that I can replicate the issue and help you out.</blockquote>
    Here are the steps to replicate the problems:
    1 ) Create JA ACM > Select block type Magazine: Topic > Under basic settings “Select an Article”
    2 ) Articles Manager > Edit any article > General tab > Select Topic.
    Hope this helps!
    Pranav
    tekdinet Friend
    #738083
    Hope this helps!
    Pranav
    #573272
    It’s very strange with that bug on your site, it looks like Plugin JA Content Type and Plugin Ajax JA Content Type are not working on this case.
    You can try going to download page here and download both plugins above and re-install it again.
    #738300
    tekdinet Friend
    #573455
    <em>@Ninja Lead 477048 wrote:</em><blockquote>It’s very strange with that bug on your site, it looks like Plugin JA Content Type and Plugin Ajax JA Content Type are not working on this case.
    You can try going to download page here and download both plugins above and re-install it again.</blockquote>
    Well, that seems to have solved the problem!
    Thanks a ton!
    tekdinet Friend
    #738482
    Thanks a ton!
This topic contains 8 replies, has 2 voices, and was last updated by  tekdinet 9 years, 5 months ago.
