  • Viorel Anghel Friend
    #150980
    after the last upgrade to joomla 1.5.17 i had some strange layout problem: the iphone layout is displayed instead of default layout. (please see the photo)
    after some time, the site load correctly. do you have any explications?
    tonyg Friend
    #343202
    Go to Template Manager and click on your default template, from the template edit page go to the header “Layout” and ensure that the “Default Layout” is set to default and NOT iphone.
    I hope this helps
    #343249
    checked, but everything is ok. now, I disabled iphone version and that works. but this is not the best solution.
    Dear pagini!
    May be the problem is from the cache browser, pls clear cache and try to check again, if possible give me the link to your site , i would like to have a closer look on the issue
    Thank
This topic contains 4 replies, has 3 voices, and was last updated by  Saguaros 14 years, 6 months ago.
