  • edd Friend
    #193443
    Hi there
    Happy New year to all of you 🙂
    Well it seems this 2014 is not going well for me: I realize that using the Bistro Theme the images in articles displayed in Category like Blog are not showing…
    In fact this is the thing:
    Using FireFox:
    I’m on the manager backend, I create the Category displaying Artcles like a blog.
    Each article shows an image and the “read more” buton.
    When I finished I clean the cache and I see that it works just fine in FireFox, but not in Chrome.
    I back to the manager backend I clean the cache, this time I use Chrome first and is working great… but not in FireFox!!!!
    So, I dont know if it is a joke or what, but it is very strange, if I clean cache and use first FireFox to see the articles, Chrome does not display the images… If I clean the cache and then I use first Chrome to see the articles, is Firefox that does not display the images…
    Anyone has the same bug?
    Any Idea?
    Thanks a lot for help
    ED
    Would be possible to have a link to your page ?
    In this way we can better check behaviour
    edd Friend
    #517301
    Sent via PM 🙂
    I checked your website
    If you check the link builded for the image the first time it has inside the index.php and gives a 404 error
    when you reload the page the link changes removing the index.php and shows correctly the image
    So i think problem is due to this settings
    try to check seo settings and also .htaccess if you have done some specific change
    edd Friend
    #517310
    Hi Pavit,
    thanks a lot for your help…
    I didn’t touch to the .htaccess, where can I chech the seo settings? wich one?
    Thanks a lot 🙂
    You need to remove the /index.php from your links
    So from Global Configuration >> SEO Settings >> Use URL rewriting set it to Yes then rename the file htaccess.txt in .htaccess
    edd Friend
    #518939
    Hi, there
    Thanks a lot, that was right and now it is working fine 😉
This topic contains 7 replies, has 2 voices, and was last updated by  edd 10 years, 12 months ago.
