  • bigitybossman Friend
    #191850
    I am using the T3 framework (Version: 1.0.8) on a clients website and they are requesting some tracking code to be placed between the closing </body> and </html> tags.
    I have tried placing it in the usual header or footer file and they are claiming that it is no working.
    Does anyone know how i can place this code between the two closing tags?
    Your help is much appreciated.
    Thank you
    Wall Crasher Developer
    #510746
    Hi bigitybossman,
    You may need to confirm with your customer again.
    For tracking code, you can insert at it before </body> or just after <head> tag
    I think it should work.
    #510815
    Hi Wall Crasher,
    Yes, i agree with you completely. I thought this was a strange request and can not understand it. I have placed the code just before the closing </body> tag and they are claiming it is not working.
    I will ask them to check again to see if it is logging and if the code they provided is correct.
    Thank you for your help.
    #512482
    I have an update on the situation.
    I have had the tracking code in before the ending </body> tag for over a week now and apparently this is not working and still not in the correct position.
    The company that provided the code must be placed between the closing </body> and </html> (which i think is very strange).
    I really need some help with this as i can’t seem to find a solution to get the code in there. Any help would be greatly appreciated.
    Thanks again.
    #512508
    Hi Guys,
    Just letting you know that i figured it out. I had to place the code into the file /plugins/system/jat3/jat3/base-themes/default/page/default.php
    Cheers
This topic contains 5 replies, has 2 voices, and was last updated by  bigitybossman 11 years ago.
