  • perfurt Friend
    #176505
    Hi ,
    I’m having the stranges problem with my Ores template running under Joomla 2.5, and I can’t figure it out at all.
    I am using the Nurte Adsense module to place the Adsense code in the Right column of the article pages, and the Adsense Ad just don’t show up on the website. I have been trough Google’s webmaster tools – they find the website OK, so it’s not a Google problem..
    At the same time I get an Explorrer message: “An add-on for this website failed to run”. I then looked at my Service on the computer to see if any Javascript was deactivated – but all was fine.
    I THINK I have narrowed it down to either the Ores template OR Joomla 2.5. But I just can’t get any further without help from a more experienced developer. My website is “www.24-7news.tv” and you can see an example of the error on the front pages right column under the heading “Annonce”.
    ANY help would be much appreciated…
    Kind regards
    Peter
    HeR0 Friend
    #450439
    I checked and do not see the error under the heading Announce. The adsense seems to be working fine in that module.
    It would be great if you could attach a screenshot pin pointing the exact issue, i shall help you out then.
    perfurt Friend
    #450655
    It looks like it’s a local browser problem here. I checked it away from home, and – as you said – all was fine.
    Strange things happen 🙂
    Thanks for looking into it!
This topic contains 3 replies, has 2 voices, and was last updated by  perfurt 12 years, 7 months ago.
