  • brusamolino Friend
    #1052287
    Hi i’ve installed the quickstart and in home on topright i have the Language Switcher module with a pulldown menĂ¹ but it hasn’t the same style like in your demo site (please see the attach file) Why?
    Thanks Luca
    1. switchlanguage
    2. switchlanguage-1
    Pankaj Sharma Moderator
    #1052509
    The submitted domain showing a different site http://prntscr.com/g2c1vu
    Can you share the site credentials in the Private reply?
    I will check it.
    brusamolino Friend
    #1052662
    #1052678
    brusamolino Friend
    #1052717
    #1052868
    Kindly share the FTP account details of site.
    The module classes are changed after the updates, I will check and correct them again.
    brusamolino Friend
    #1052954
    #1052959
    I turn on the Language flags from the module and its working fine now.
    Please check your site.
    brusamolino Friend
    #1052961
    Thanks!
    What have you modified?
    Best regards
    Luca
    #1052963
    Nothing is changed. Just turn on the show flag from language switcher module.
    brusamolino Friend
    #1052987
    Sorry
    have you changed something in home template?
    Because now the home is not like in your demo webstite
    Luca
    #1052989
    no, Nothing is changed, the only change is set the language flag to ON.
    Also, your site looks same as it was before.
    brusamolino Friend
    #1052990
    I don’t know why the now home has a different layout… like the internal pages
    Can you help me to restore the home like in your demo site?
    Best regards
    Luca
    #1052991
    Kindly follow this documentation to get the site like in the demo.
    Also if you want some sample data like in the demo, i suggest you install the quickstart package.
    If you face any issue open a thread on the forum with the topic subject and we will help you.
This topic contains 13 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 4 months ago.
