  • Município de Vila Real Friend
    #1019512
    I am not able to remove the sub-menu under the home page, where is that option? There are no items but i still get a black rectangle under the home menu.
    Thank you
    1. Screen-Shot-2017-03-17-at-14.54.30
    Pankaj Sharma Moderator
    #1019948
    Kindly open the template options > Mega Menu > Select menu > Now click on the Menu item that showing the submenu block > Show submenu > NO.
    Save and check.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 9 months ago.
