  • aokweb Friend
    #119074
    I have a bit of a wierd thing going on. I have been trying to create a sub-nav menu in the left column of this template here: http://www.aokwebhost.comfor like 72 hours. I want the same type of sub-menu like the ones under the, ” menu options” in the joomlart.com templates demos. Does anyone have any instructions for doing this. I am lost and desperate for any help. Thanks.
    ha le-viet Developer
    #215347
    Hi aokweb,
    I don’t understand exactly what do you mean but I assume that you are talking about split menu which was implemented in your site already.
    Can you describe more clearly?
    Regards,
    Ha Le-Viet.
This topic contains 2 replies, has 2 voices, and was last updated by  ha le-viet 17 years, 9 months ago.
