tapavakos Friend
tapavakos
- February 2013
September 3, 2013 at 9:03 am #190238Hello ,
As you can see to my website, i open a submenu like “ΕΙΔΗΣΕΙΣ ΣΕ 1” > ΟΙΚΟΝΟΜΙΑ” and then submenus dont show , dont scrolling down. You check it to see what exactly i mean.
Navigate here http://www.paredwse.net/index.php/feed/oikonomia and try to mouse over to main category menu “ΕΙΔΗΣΕΙΣ ΣΕ 1” , submenu not showing. If you navigate to home page and navigate with your mouse to “ΕΙΔΗΣΕΙΣ ΣΕ 1” submenu working well.
Sorry , for my bad english..
Saguaros ModeratorSaguaros
September 4, 2013 at 3:52 am #504472Hi tapavakos,
There seems to be conflict in js so that the dropdown menu doesn’t work, did you install any 3rd party extension in your site? Try going to template manager and set Compress JS to No, if you use editor like Firebug in Firefox > check error, you will see where the error comes from.
tapavakos Friendtapavakos
- February 2013
September 4, 2013 at 9:31 am #504523Hello ,
thanks for your reply. I use 3rd party extension “ultimate deef display”. When i set Compress JS to No submenus wotk well. If i leave this option disabled which is the different to my website? What exactly doing Compress JS ?
Christoforos
September 4, 2013 at 10:55 am #504547Hi Christoforos,
Is that a module? It may contain js file and have problem when it’s compressed, you can try to add that js file into: Optimize Exclude in template manager and enable Optimize JS option again.
Remember to clean JAT3 cache then.
- February 2013
September 4, 2013 at 10:58 am #504549It is module http://extensions.joomla.org/extensions/social-web/social-display/rss-readers/12567.
Could i have more info how to add js?
Christoforos
September 5, 2013 at 4:34 am #504640Hi Christoforos,
I don’t have this module so I don’t know which file it’s using, you can go to folder of this module and find if there is any js file it uses and add into Optimize Exclude like I mentioned above.
- February 2013
September 5, 2013 at 11:13 am #504723Hello Saguaros,
I did as you said . I found 3rd party module and copied all .js + .css files into “Optimize Exclude”. Then , i cleaned my cache and enable Optimize JS but the problem still exists. Correct me if i am wrong.
I uploaded two images for my changes.
Christoforos
September 6, 2013 at 10:24 am #504863Hi
You can send me a pm with admin and ftp account of site you’re working on, I will check it for you.
- February 2013
September 6, 2013 at 10:49 am #504869Done! I sent pm.
- February 2013
September 8, 2013 at 2:52 pm #504944Hello Saguaros
I sent pm with account info.
Viewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 2 voices, and was last updated by tapavakos 11 years, 2 months ago.
