turminator Friend
turminator
- August 2008
- 4 times in 1 posts
February 22, 2011 at 7:55 pm #160571I installed this template in my joomla installation and I detect critic problems with:
- Firefox 3.6 submenu items not works.
- In Internet Explorer submenu works but it shos a message that website laods but with errors
You can see it at:
I need help.
Many thanks!
February 23, 2011 at 8:07 am #378056The issue happened because
1) You enabled the Mootools Upgrade Plugin
+> Currently, the template could not work well when you enabled this, I informed Our developers checking the issue.2) The jquery loaded before the mootools, you view html source of the home page you will see these
[PHP]
<script type=”text/javascript” src=”http://www.medicinaub.com/components/com_community/assets/joms.jquery.js”></script>
<script type=”text/javascript” src=”http://www.medicinaub.com/components/com_community/assets/script-1.2.js”></script>
<script type=”text/javascript” src=”http://www.medicinaub.com/components/com_community/assets/window-1.0.js”></script><script type=”text/javascript” src=”http://www.medicinaub.com/components/com_community/assets/joms.ajax.js”></script>
<script type=”text/javascript” src=”/plugins/system/mtupgrade/mootools.js”></script>[/PHP]
=> fix this: the mootools libs load before jquery
turminator Friend
turminator
- August 2008
February 23, 2011 at 7:40 pm #378153Hello tienhc,
Thanks for your help. I disabled mootools upgrade plugin but problem with submenu links not solve. You can see it in this view:
http://www.medicinaub.com/index.php?option=com_kunena&view=listcat&catid=0&func=listcat&Itemid=195
And try to click with firefox in submenu located in second item.
I try to do point two but I don’t understand what steps I need to do this modification.
<blockquote>The jquery loaded before the mootools, you view html source of the home page you will see these </blockquote>
EDIT: Some users says me that submenus not works with Safari and Firefox.
Many thanks!
February 24, 2011 at 6:45 am #378231Hello Mate
Please view my snapshot, the menu works well on all browers, Now you press keys ctr + f5 to check this issue again
turminator Friend
turminator
- August 2008
February 24, 2011 at 9:35 am #378256Hello,
Yes submenu open with all navigators but link not works on: Firefox and Safari navigators. Only you can click on link called “Compartir els meus apunts” with Internet Explorer.
Many thanks!
February 25, 2011 at 2:02 am #378330You add the following code into the template.css file
.childcontent-bg{
display:none
}turminator Friend
turminator
- August 2008
February 28, 2011 at 9:04 am #378796Many thanks tienhc!
It seems that now works correctly!
This topic contains 7 replies, has 2 voices, and was last updated by turminator 13 years, 11 months ago.
