Sylwester Kowalski Friend
Sylwester Kowalski
- 7 times in 1 posts
May 16, 2013 at 7:48 pm #187562Hi,
I’m having a lot of trouble locating the code to move my sub menu(under services) a little bit more up.
Also, I wanted change the speed at which the sub menu comes down, make it a little bit slower. I assume that’s probably somewhere in the same file.
If anyone can help me out or at least point me in the right direction, it’d be greatly appreciated.
Thanks in advance.
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
May 17, 2013 at 4:00 am #493072Hi sly123,
<blockquote>I’m having a lot of trouble locating the code to move my sub menu(under services) a little bit more up.</blockquote>
You need to open templates/ja_blazes/css/menu/mega.css, then find & replace padding-top value:.mid { padding-top: 15px; position: relative; }
<blockquote>Also, I wanted change the speed at which the sub menu comes down, make it a little bit slower. I assume that’s probably somewhere in the same file.</blockquote>
You can go to Template Manager >> JA_Blazes – Default >> Profiles tab >> Default (i.e) >> Menu settings >> Animation duration. Enter your value.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by phong nam 11 years, 6 months ago.
