  • mexx uk Friend
    #131261
    If I try to create a submenu item article, I get this error:
    404 – Component not found
    You may not be able to visit this page because of:
    1. an out-of-date bookmark/favourite
    2. a search engine that has an out-of-date listing for this site
    3. a mistyped address
    4. you have no access to this page
    5. The requested resource was not found.
    6. An error has occurred while processing your request.
    Please try one of the following pages:
    * Home Page
    If difficulties persist, please contact the System Administrator of this site.
    Component not found
    However if I publish it in the ‘Top’ position it fine, it will go to the article associated with it.
    Any ideas???
    Many thanks.
    (Running on Joomla 1.5.3)
    #261884
    Can you send your URL and an admin account via Pm ?
    #262131
    i configed SEO again for you
    See attachment
    2280
    mexx uk Friend
    #262273
    Wow, thanks. I would never had guessed it would be those settings – always the simple things!!
    Many thanks!:D
    #262295
    Ok
    I will mark this topic is solved
This topic contains 5 replies, has 2 voices, and was last updated by  Sherlock 16 years, 5 months ago.
