  • ryanlama Friend
    #130499
    Trying to install joomla and learn this thing.
    I have successfully installed it using the quickstart package.
    I registered as a user and tried submitting an article i get error.
    I also noticed that the access lever is set to special
    anyone help me clarify the purpose of the special access level.
    thanks much
    questbg Friend
    #258113
    Hi ryanlama
    Have you tried to edit or submit an article using the Article Manager in the Admin panel?
    Also, are you using Joomla 1.0 or 1.5?
    ryanlama Friend
    #258114
    You mean from the backend? 1.5.
    It’s good there as i’m looged in as an admin
    questbg Friend
    #258115
    What ‘user level’ did you try when you try to submit an article via the browser?
    ryanlama Friend
    #258116
    I just wondered what is the deal with the “special” permission category?
    If i bump the user to higher than registered it looks like it will work.
    I have spent around 20 hrs edtiting all the CSS to look the way i want to still learning 🙂
    byjup Friend
    #258373
    I am also having the same proble.
    ryanlama Friend
    #258390
    the submission problem?
    this template has it so registered users can’t submit.
    Up the level of the user and you should be fine.
    byjup Friend
    #258392
    cool.. I think that works.. thank u.
This topic contains 8 replies, has 3 voices, and was last updated by  byjup 16 years, 5 months ago.
