7of9 Friend
7of9
- December 2010
- 25 times in 3 posts
August 26, 2013 at 2:14 pm #190047Hi,
I understand that in order to tag a product “hot” you need from custom fields to add a ja-product-type custom field type and set the value to hot. (I did not find any explanation in the guide, I saw from experience. Maybe it’s a good idea to add it.)
However, I made a few changes to a couple of products and it’s not working for them. You can see it here: http://www.allmassage.gr/en/treatments/packages
Only in one product it’s working.Please advice.
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
August 27, 2013 at 4:41 am #503554Hi 7of9,
Can you try to put the label “hot” into the custom fields of that products again? Lets send me PM with your website’s credentials if the issue still persists. I will be happy to check it for you. And tell me which products you want to display that label.
7of9 Friend7of9
- December 2010
August 27, 2013 at 12:29 pm #503632Hi Leo,
PM sent.
Thanks in advance.
- May 2015
August 27, 2013 at 2:05 pm #503639Hi 7of9,
It is quitely weird. The same problem on our JA Hawkstore demo site that not all products selected with “hot” custom fields will display correctly the hot label. Lets me ask our template developer, maybe he will have better explanation on this issue, I will back to reply you tomorrow morning.
1 user says Thank You to phong nam for this useful post
7of9 Friend7of9
- December 2010
August 27, 2013 at 2:21 pm #503641Hi Leo,
Did you make any changes to the css? Because all the modifications I have done, are undo now.
ie: I had change the background color, the size of the logo, etc.7of9 Friend7of9
- December 2010
August 27, 2013 at 2:42 pm #503647It turns out that you turned off development mode, so all my changes were disabled. I have moved them now to custom.css and turned off development mode, so it will not happen again.
However, this is a production site, so please when you change something, remember to change it back. 🙂Thanks for your effort.
1 user says Thank You to 7of9 for this useful post
- May 2015
August 27, 2013 at 2:50 pm #503648Hi 7of9,
I have seen your reply. I will reply you again tomorrow !
Regards,
Leo
- May 2015
August 28, 2013 at 11:14 am #503776Hi 7of9,
I have reminded our template developer on this issue of JA Hawkstore template, and a issue report is raised at http://pm.joomlart.com/browse/JATCHAWKS-95 so that you can keep track on its work flow. Our developer needs some time to check the custom field conditional functions to find out the reason. Hope that the issue fix will be included in the next update in coming time.
P/s: I’m really sorry for not rolling back the Enabling Development mode yesterday evening.
7of9 Friend7of9
- December 2010
August 28, 2013 at 11:10 pm #503828Hi Leo,
Thanks for your reply. I don’t think I have access to this site. I tried my joomlart credentials, but it did not let me in.
No problem about the Enabling Development mode, I just inform you about the status of the web site, so you will know in the future. 🙂
Please ask the developer to let us know eventually how he fix it, because I cannot install everything from the beginning. I need a fix for this specific problem, since the site is finished and in production.
Thanks in advance. 😀phong nam Friendphong nam
- May 2015
August 29, 2013 at 3:29 am #503861Hi 7of9,
The issue bug ticket is set for public access at http://pm.joomlart.com/browse/JATCHAWKS-95. Sure, I will follow this issue until the update with the fix is going to be available. Thank you for your patience !
Leo
7of9 Friend7of9
- December 2010
7of9 Friend7of9
- December 2010
August 30, 2013 at 1:24 pm #504104I confirm that the same problem exists in the tags “sale” and “new”.
- May 2015
September 3, 2013 at 2:26 am #504295Hi 7of9,
There are some priority tasks our template developers have to finish in releasing the September template – JA Muzic, so that they will check and update the issue fix of “hot” and “sale” custom field issues on JA Hawkstore template then. Hope you can be patient for it.
This topic contains 20 replies, has 2 voices, and was last updated by 7of9 11 years ago.
