antoniocerasuolo Friend
antoniocerasuolo
- February 2011
- 7 times in 1 posts
February 26, 2011 at 8:10 pm #160744hello,
I need the kunena in italian… do you know where i can find the italian language?? .. i already installed the italian language for the joomla front end… but need the italian for kunena forum also!
Nick R JA JobBoardNick R
- August 2009
- 20 times in 1 posts
February 26, 2011 at 9:26 pm #378559Hi Antonio,
You may want to have a look here:
http://www.kunena.org/forum/advsearch?q=italian+language+packCheers
Nickantoniocerasuolo Friendantoniocerasuolo
- February 2011
February 26, 2011 at 9:38 pm #378560Nick thanks..
can i ask a second question??? I am looking for the directry where i need to place the logo if i want to use a logo instead of text..
and i noticed that the kunena forum also has the JA logo where do i need to place my logo to substitute those also??
regards,
AntonioNick R JA JobBoardNick R
- August 2009
February 26, 2011 at 9:44 pm #378562Find your logo here :
/templates/ja_sulfur/images/logo.png
🙂Cheers
- February 2011
February 26, 2011 at 9:49 pm #378564Nick..
Thanks..
i downloaded the kunena italian pack.. to i just install it as any joomla add on???
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
February 26, 2011 at 10:13 pm #378569All the instructions on Kunena and their language packs can be found on the Kunena site. They have quite extensive docs and very good support so you would be better off asking Kunena related problems over there.
- February 2011
February 26, 2011 at 11:39 pm #378583hey phil..
thanks..one last question .. is vbulleting able to be imbedded into joomla like kunena????
- February 2014
February 27, 2011 at 6:52 pm #378640It is possible using what is known as a bridge component such as jfusion. However, it can cause a lot of work if you are new to this sort of thing. You also would probably need to know a bit of css and html to get the integration to look good. I would stick with Kunena or Agora if you want an easy life.
- February 2011
March 1, 2011 at 4:58 pm #379105All,
can i disinstall the current version of Kunena that was included with the sulfur template and install this new version which includes the italian??
- February 2014
March 1, 2011 at 8:24 pm #379137You probably could but there are 2 reasons why it might not work as expected. First thing to try would be to go into the plugins manager and turn on the moo tools upgrade plugin. Then fully test your current setup and make sure everything works as expected.
If that works then in theory you can install the latest version of Kunena. The proble you will have is one of styling. Sulfur had a theme built for Kunena 1.5 so on the forum page you get a styling that fits nicely with the design of Sulfur. Kunena 1.6 uses a completely new theme engine so you would either have to put up with one of the themese downloadable from the Kunena site or code a new theme to fit perfectly yourself.
This topic contains 10 replies, has 3 voices, and was last updated by Phill 13 years, 9 months ago.
