  • James Weston Friend
    #181603
    Hi Guys,
    I found a great answer on the forum yesterday for the code to get a .swf banner working on my site http://www.millionaireasia-indonesia.com
    If you look on the site you will see the banner runs but only once and does not loop or repeat. Can anyone suggest what I could add to the code to make this happen?
    I am using the code:
    <left>
    <p><a href=”http://www.millionaireasia-indonesia.com/” target=”_blank”>
    <OBJECT classid=”clsid:D27CDB6E-AE6D-11cf-96B8-444553540000″ codebase=”http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0″ width=”728″ height=”90″ align=”center”>
    <PARAM name=”movie” value=”http://www.millionaireasia-indonesia.com/images/flash/qatar.swf”>
    <PARAM name=”quality” value=”high”>
    <PARAM name=”allowScriptAccess” value=”always”>
    <param name=”wmode” value=”transparent”>
    <EMBED src=”http://www.millionaireasia-indonesia.com/images/flash/qatar.swf” width=”728″ height=”90″ align=”middle” quality=”high” type=”application/x-shockwave-flash” pluginspage=”http://www.macromedia.com/go/getflashplayer” allowScriptAccess=”always” wmode=”transparent”> </EMBED>
    </OBJECT>
    </a></p>
    </left>
    Cheers,
    Jim
    Try to add this
    <param name ="loop" value = "true">
    James Weston Friend
    #470756
    Thanks Pavit. so now I have:
    <left>
    <PARAM name =”loop” value = “true”>
    </OBJECT>
    </a></p>
    </left>
    But unfortunately, that does not seem to have made any difference. I have saved it and cleaned the cache but it still stops after the first rotation.
    Jim
    Try to change the value “true” to “1”
    James Weston Friend
    #470765
    Thanks Pavit, but still not doing anything different. Any other ideas?
    I have searched google but have not found anything yet.
    Jim
    James Weston Friend
    #471266
    Does anyone have any ideas on how to get .swf banners looping?
    Jim
This topic contains 6 replies, has 2 voices, and was last updated by  James Weston 12 years, 1 month ago.
