djdlife Friend
djdlife
- November 2014
February 16, 2015 at 10:55 am #203833Hi
I have Problem with this Template, when i writig a Syntax in a artciel, don’t working. For example: I writing in a articel this Syntax {loadposition login}, is the output as plain text.
See here:
Why?
Thanks for help me.
Greetings,
eagledk Friendeagledk
- October 2013
- 7 times in 1 posts
February 16, 2015 at 12:40 pm #559610You are not alone.
I have the same problem and here is two more:
http://www.joomlart.com/forums/topic/no-3rd-party-plugins-are-working/
http://www.joomlart.com/forums/topic/content-plugins-not-working-in-articles-any-type/
So I really hope that they will find a solution very fast, because I expect to relase my new design wednesday.
Morten
boursicoton Friendboursicoton
- August 2012
- 2 times in 1 posts
February 16, 2015 at 1:22 pm #559619Modifier le fichier ‘/html/layouts/joomla/content/item/default.php’ dans le template ‘ja_teline_v
<section class=”article-content” itemprop=”articleBody”>
<?php echo JLayoutHelper::render(‘joomla.content.info_block.topic’, array(‘item’ => $item)); ?>
<?php echo $item->text; ?><?php if ($params->get(‘show_tags’, 1) && !empty($item->tags)) : ?>
<?php echo JLayoutHelper::render(‘joomla.content.tags’, $item->tags->itemTags); ?>
<?php endif; ?>
</section>Modifier le fichier ‘/css/custom.css’ dans le template ‘ja_teline_v’
.article-content-main section.article-content p:first-child {
display: none;
}djdlife Frienddjdlife
- November 2014
February 16, 2015 at 1:26 pm #559620<em>@eagledk 458864 wrote:</em><blockquote>You are not alone.
Morten</blockquote>
but i found a salution, but thats is not good. Do you using this Template(Teline V)? Then i have a salution for you, but then don’t working with typography.
- November 2014
February 16, 2015 at 1:28 pm #559621<em>@boursicoton 458875 wrote:</em><blockquote>
<?php echo $item->text; ?>}</blockquote>
If you used this code, then don’t working with the typography. You have a other Solutions?
- October 2013
February 16, 2015 at 1:34 pm #559622Hi boursicoton,
Thanks for you info.
But if I make theese changes, then my plugin starts working, but I still see the tag for the plugin, and all text and positions are crapping up.
Please see this page:
http://www.campingbutikken.dk/artikler/25-arrangementer/777-mini-mus-og-bulldog1
Morten
- November 2014
February 16, 2015 at 1:36 pm #559623Can you post your Script here?
- October 2013
February 16, 2015 at 1:36 pm #559624Thanks djdlife,
As you can see I just tried it out with mixed results, as you informed about.
Morten
- October 2013
February 16, 2015 at 1:38 pm #559625<em>@djdlife 458879 wrote:</em><blockquote>Can you post your Script here?</blockquote>
Me?
And what script?
I just made the change about the “text: ?” and the custom.css.
- November 2014
February 16, 2015 at 1:38 pm #559626[PHP] Change this Code:
<?php echo $item->fulltext; ?>}
to
}[/PHP]
- October 2013
February 16, 2015 at 1:39 pm #559627<em>@djdlife 458882 wrote:</em><blockquote>[PHP] Change this Code:
to
}[/PHP]</blockquote>
I just did.
- August 2012
February 16, 2015 at 1:39 pm #559628rollback with templates ja templates teline v 1.0.0 ….. bug is on 1.0.1 !!!
with 1.0.0 all it’s workingdjdlife Frienddjdlife
- November 2014
February 16, 2015 at 1:46 pm #559629<em>@boursicoton 458884 wrote:</em><blockquote>rollback with templates ja templates teline v 1.0.0 ….. bug is on 1.0.1 !!!
with 1.0.0 all it’s working</blockquote>Do you found a solutions for the Typography?
- August 2012
February 16, 2015 at 1:51 pm #559632typography isn’t used on my website, i use default utilities …
http://www.ichimoku.fr1.0.1 with change layout and custom css
- November 2014
February 16, 2015 at 2:07 pm #559636<em>@boursicoton 458888 wrote:</em><blockquote>typography isn’t used on my website, i use default utilities …
http://www.ichimoku.fr1.0.1 with change layout and custom css</blockquote>
When you don’t use Typography, what is this: http://www.ichimoku.fr/index.php/inscription-login-contact-divers/utilisation/540-se-servir-du-site-les-formations
This topic contains 16 replies, has 3 voices, and was last updated by boursicoton 9 years, 11 months ago.
