  • ghz84 Friend
    #192384
    first of all, thanks to JoomlArt for this fantastic framework.
    I’ve read all the documentation on T3v3 to understand how to personalize the template for my purpose, that is clear and complete, but I can’t find information about module positions to understand what positions are included in each block. Is there any a guide/scheme about default module position of the various T3v3 blocks?
    I know that i can see the code inside the php files, or create a style with all blocks and use tp=1 to show the positions but if there is a guide, would be more easy and clear.
    Thanks.
    Bye,
    GHz
    You can find all the Documentation for T3V3 Framework HERE
    Documentation for module position included
    ghz84 Friend
    #512853
    <em>@pavit 398561 wrote:</em><blockquote>Hi
    Documentation for module position included</blockquote>
    Hi pavit,
    sorry, I’ve already read the official documentation but I can’t find any information about module positions inside default blocks. Maybe i’m a bit confused, so please can you link exactly where is it?
    Thanks for your patience and support.
    Bye,
    GHz
    There is no other documentation about modules in T3V3 framework
    The one i gave above is enough exaustive about new modules creation and management
    If you have already installed the T3 Blank template you will notice all the blocks positions configuration inside single module.php file
    spotlight-1 ( positions 1 to 4 ) spotlight-2 ( positions 5 to 8 )
    anyway in forum there are many threads showing various situations and customizations for various templates
    so the best way to learn i think is to read all forum posts regarding it
    But you will need to renew your membership 😉
    ghz84 Friend
    #512949
    <em>@pavit 398727 wrote:</em><blockquote>Hi
    But you will need to renew your membership ;)</blockquote>
    Hi pavit,
    sure, the documentation is excellent, but I thought there was even a modules map like this: http://wiki.joomlart.com/wiki/JA_Template_Framework/Guides#The_JA_Purity_II_layouts
    Thanks for the reply, no problem, I will find the informations inside .php files.
    Bye,
    GHz
This topic contains 5 replies, has 2 voices, and was last updated by  ghz84 11 years ago.
