  • muhteren Friend
    #640244
    please look this subject: http://kibristesisat.com/blog/234-kibris-araba-far-temizligi.html
    the tags are above.
    I want to get down…
    jooservices Friend
    #645001
    Hi there
    Please check into html/com_content/article.php and modify it as your needed.
    If you can’t work on it. Please provide your site backend & CPanel access. I’ll help you work on it.
    Thank you,
    Viet Vu
    muhteren Friend
    #645008
    I send my site cpanel password and name
    muhteren Friend
    #645014
    article.php
    Send the edited version of the file
    muhteren Friend
    #645168
    <?php if ($params->get(‘show_tags’, 1) && !empty($this->item->tags)) : ?>
    <?php echo JLayoutHelper::render(‘joomla.content.tags’, $this->item->tags->itemTags); ?>
    <?php endif; ?>
    templatesja_medicarehtmlcom_contentarticle/default-blog1.php
    open this file and
    find the above code
    and cut
    and
    paste 197. row that’s all.
    I did it….
    muhteren Friend
    #743793
    <?php endif; ?>
    open this file and
    find the above code
    and cut
    and
    I did it….
    jooservices Friend
    #645169
    Glad to see that.
    Thank you,
    Viet Vu
    jooservices Friend
    #743794
    Glad to see that.
    Thank you,
    Viet Vu
This topic contains 8 replies, has 2 voices, and was last updated by  jooservices 9 years, 4 months ago.
