October 16, 2014 at 10:51 am #202136
I have a lot of products which belong to different tags (category) under each brand. It will show 20 items when I load that page.
1. How do you adjust the number of items display in each page first load?
2. As seen in the pictures, if I select Model T, it doesn’t show the model T items because it isn’t loaded on the first page. How do you solve this problem?
3.. Please refer to website.png. By default, it shows the product name for items that is created with a gallery. However, I want the name hidden like creating a single picture item. At the same time, I always want the item name shown in tablet and cell phone because there’s no hover option.
Please help me out.
Thanks.
Eragon H Friend
Eragon H
- July 2014
- 156 times in 149 posts
October 17, 2014 at 2:07 am #553309Can you share your site URL and temporary admin account, so I can have a look with your concerns
October 17, 2014 at 3:50 am #553326hi? anyone there?
October 17, 2014 at 11:13 am #553373Ok, I will PM you.
Thanks.Eragon H FriendEragon H
- July 2014
October 20, 2014 at 3:52 am #5535381. Change number items of page load
a. For the home page: Menu >> Main Menu en (same for other languages) >> Home >> http://prntscr.com/4xw2f0
b. For other pages : Setting >> Global Configuration >> Default List Limit >> http://prntscr.com/4xw2ly2. You can set the higher value of “Default List Limit” (for example: 100), so it will load all items first
3. I can see you disbaled right-click in your site, kindly enable it so I can check for solutions
October 20, 2014 at 5:17 am #553556I have already pm Eragon H but still I still get no response….Why?
Could any please help me for real?
October 20, 2014 at 7:20 am #5535692. For some brands I have more than 100 products and it takes too long to load it. Is it possible for you to make a tweak so that it will also filter products that aren’t displayed yet?
3. Can you use this instead?
CTRL + U: View source code of the current page
Thanks.
- July 2014
October 20, 2014 at 8:40 am #553585I need the right-click to check things which can’t be done with the source code. So, can you enable it in your site
October 30, 2014 at 8:47 am #553701Hi,
Howcome we lost the 2nd page? How can we retrieve the hidden questions and answers 🙁
- July 2014
October 31, 2014 at 11:15 am #553774Hi,
There is unexpected issue with the server and we’ve lost data for recent 10 days.
Regarding your concern with tag filter, you can check the progress here: http://pm.joomlart.com/browse/JATCFIXEL-251
We are sorry for any inconvenience and feel free to let us know if you have any further question.
November 24, 2014 at 5:59 pm #556354Hi,
1. When can this be fixed? This is really causing a lot of trouble.
2. Are there lots of bugs in the code? I always get lots of error like the attachment.
3. I used to use a previous joomla site. Now that I have switched it to a different domain name and it is not working anymore. Is there a place in the database that has hard coded the site name to do the mapping? Could you please advise?
Eragon H Friend
Eragon H
- July 2014
November 25, 2014 at 5:06 am #5564341. Our team are working on this template for releasing the new version and of course including the fix for above bug, kindly wait for the update.
2. This error only occurs when you moving to new domain, doesn’t it?
Can you provide the temporary admin account. I can have a closer look. The old one doesn’t workNovember 25, 2014 at 6:22 pm #5565161. No, it happened in my old site as well. The problem is the more data I input, the more errors I get. I get these kind of errors around 25% of the time. 🙁
2. If you go to the previous site, you would see all the broken links. Do you know if anywhere in the code is mapping it to richcoln.com? I have a hard time finding it.
3. After you are logged onto the site, could you please go to news, select this language “繁” and try loading all data by clicking “load next data”? The query keeps on running non stop and is continuously displaying the same data. I have highlighted it in the attachment.
- July 2014
November 26, 2014 at 8:56 am #5566111. Have you tried this guide to change the domain name of you site: http://www.inmotionhosting.com/support/edu/joomla-3/site-settings/changing-url-joomla-website
2. I will be back to you as soon as the bug is fixed.
- July 2014
November 28, 2014 at 3:59 am #556890Hi,
Our development team has fix the issue in your site. Kindly re-check and let we know if there is still bug
AuthorPostsThis topic contains 50 replies, has 3 voices, and was last updated by Ninja Lead 9 years, 9 months ago.
