December 17, 2014 at 8:06 am #558882
2. It is still happening.
3. Thanks. How can I change the color myself?
4. Thanks.
5. I have a new error.
Error
Incorrect key file for table ‘/var/tmp/#sql_30e_6.MYI’; try to repair it SQL=SELECT a.id, a.title, a.alias, a.introtext, a.fulltext, a.checked_out, a.checked_out_time, a.catid, a.created, a.created_by, a.created_by_alias, CASE WHEN a.modified = ‘0000-00-00 00:00:00’ THEN a.created ELSE a.modified END as modified, a.modified_by, uam.name as modified_by_name,CASE WHEN a.publish_up = ‘0000-00-00 00:00:00’ THEN a.created ELSE a.publish_up END as publish_up,a.publish_down, a.images, a.urls, a.attribs, a.metadata, a.metakey, a.metadesc, a.access, a.hits, a.xreference, a.featured, a.language, LENGTH(a.fulltext) AS readmore,CASE WHEN badcats.id is not null THEN 0 ELSE a.state END AS state,c.title AS category_title, c.path AS category_route, c.access AS category_access, c.alias AS category_alias,CASE WHEN a.created_by_alias > ‘ ‘ THEN a.created_by_alias ELSE ua.name END AS author,ua.email AS author_email,parent.title as parent_title, parent.id as parent_id, parent.path as parent_route, parent.alias as parent_alias,ROUND(v.rating_sum / v.rating_count, 0) AS rating, v.rating_count as rating_count,c.published, CASE WHEN badcats.id is null THEN c.published ELSE 0 END AS parents_published FROM tb_content AS a LEFT JOIN tb_categories AS c ON c.id = a.catid LEFT JOIN tb_users AS ua ON ua.id = a.created_by LEFT JOIN tb_users AS uam ON uam.id = a.modified_by LEFT JOIN tb_categories as parent ON parent.id = c.parent_id LEFT JOIN tb_content_rating AS v ON a.id = v.content_id LEFT OUTER JOIN (SELECT cat.id as id FROM tb_categories AS cat JOIN tb_categories AS parent ON cat.lft BETWEEN parent.lft AND parent.rgt WHERE parent.extension = ‘com_content’ AND parent.published != 1 GROUP BY cat.id ) AS badcats ON badcats.id = c.id INNER JOIN tb_content_frontpage AS fp ON fp.content_id = a.id WHERE a.access IN (1,1) AND c.access IN (1,1) AND CASE WHEN badcats.id is null THEN a.state ELSE 0 END = 1 AND (a.publish_up = ‘0000-00-00 00:00:00’ OR a.publish_up <= ‘2014-12-17 08:01:47’) AND (a.publish_down = ‘0000-00-00 00:00:00’ OR a.publish_down >= ‘2014-12-17 08:01:47’) AND a.language in (‘en-GB’,’*’) ORDER BY a.featured DESC, fp.ordering, a.created DESC , a.created DESC LIMIT 0, 20
Eragon H Friend
Eragon H
- July 2014
- 156 times in 149 posts
December 17, 2014 at 8:21 am #5588842. You can provide the resolution of your Samsung screens. I will try to re-produce at my end. As this issue only occur in a your screen. It’s not easy to fix without directly checking.
3. You can change the color value of below code in the file root/templates/ja_fixel/css/custom.css
div#infinity-next {
background: #0093C3 !important;
border: none !important;
}4. What have you changed recently?
How can I re-produce it? Or it happen randomly?
It seems this issue closely relating to the 1st issue. Kindly let me know the result after checking with your hosting providerMarch 2, 2015 at 10:07 am #561213Hi @eragon H,
Thanks for your previous help. They worked it would be great if you could help me again.
1. I tried adding the social buttons but having difficulties on the sinaweibo and linkedin account.
<a class=”addthis_button_sinaweibo_follow” addthis:userid=”richcolninfo”></a>
http://www.weibo.com/richcolninfo<a class=”addthis_button_linkedin_follow” addthis:userid=”richcoln-company-limited”></a>
now it goes to https://www.linkedin.com/in/richcoln-company-limited but it should be https://www.linkedin.com/company/richcoln-company-limitedIs this the right way to do it? It’s only returning to the same same if I click onto the button.
2. My social media buttons at the top right changed into a different icon on their own. I’m not sure why, please see picture 1. I want the old style back (white and light grey).
3. My articles aren’t showing the created date even though I have set it to be shown in the global setting. An example would be under “world of Richcoln” -> “news” -> any article
Ninja Lead Moderator
Ninja Lead
- November 2014
- 3854 times in 3563 posts
March 3, 2015 at 8:12 am #561362March 4, 2015 at 8:56 am #561533I did already, but it doesn’t work.
<div class=”addthis_toolbox addthis_floating_style addthis_32x32_style”>
<a class=”addthis_button_facebook”></a>
<a class=”addthis_button_linkedin”></a>
<a class=”addthis_button_twitter”></a>
<a class=”addthis_button_google_plusone_share”></a>
<a class=”addthis_button_sinaweibo”></a></div>
Also, now the icons are with its original color, I want to be able to get the grey and white icons back.
3. This is really causing a lot of trouble! My articles aren’t showing the created date even though I have set it to be shown in the global setting. An example would be under “world of Richcoln” -> “news” -> any article
Ninja Lead
- November 2014
March 5, 2015 at 7:50 am #561698You can pm me URL of your site and admin login of your site. I will help you to check it further.
March 6, 2015 at 2:13 pm #561913ok, I will pm you now thanks
Ninja Lead
- November 2014
March 11, 2015 at 5:16 am #562525what’s the size of the black and white icon?
and you have missed this question
thx
Ninja Lead
- November 2014
March 11, 2015 at 10:15 am #562592You can give me the screenshot and description on that and URL of your reference the problem on your site. I will check it for you.
March 11, 2015 at 10:40 am #562604Thanks soooooooo much
Ninja Lead
- November 2014
March 12, 2015 at 8:44 am #562772<em>@rclpris 462798 wrote:</em><blockquote>Thanks soooooooo much</blockquote>
I spent a lot of my time to fixing the problem directly on your site, because you have to add some social icons which is not included in JA Fixel template by default.
You can remove it you will get back the white and black like our demo, see the screenshot
March 13, 2015 at 4:37 am #562907Thanks. I’ve searched everywhere to replace the icons but fail. Could you please give me some hint on the location of the 4 images? Two on the top right and two for ja bookmark. Thanks
Ninja Lead
- November 2014
March 13, 2015 at 8:50 am #562946You can find the location of image here:
top: templates/ja_fixel/images/ico-social.png
left: templates/ja_fixel/images/JA_Bookmark_Fix.pngYou also have to add new black and white icons were short into both images and change some styles on that.
March 17, 2015 at 3:08 pm #563450Thanks @ninja Lead,
I have created the new image and modified the code, however, the social buttons for the ja bookmark is moved to the top left for some reason, please see screenshot.
Also on the top right corner, the hidden button of the social button has turned black, how can you switch it back to the original white. Thanks.
This topic contains 50 replies, has 3 voices, and was last updated by Ninja Lead 9 years, 10 months ago.
