puntje Friend
puntje
- April 2014
- 4 times in 3 posts
July 3, 2015 at 12:53 pm #208214The tag-page will not work. It will not save
Error
Save failed with the following error: exception ‘UnexpectedValueException’ with message ‘TagsTableTag::_getNode(1, ) failed.’And more errors. In my other website it works. But with this template i cannot place tags.
July 4, 2015 at 1:58 am #576337Hello
Did you updated your Joomla Recently ? this is a know issue in Joomla and mostly comes after joomla update .
Try to repair DB tables from Php my admin first
Follow the solution given here
If it does not work you can write the issue on the same thread on Joomla Forum or open a new post so you can get solution for this Joomla Tag error .Pankaj Sharma ModeratorPankaj Sharma
July 4, 2015 at 1:58 am #642658Hello
July 4, 2015 at 1:58 am #741315Hello
If it does not work you can write the issue on the same thread on Joomla Forum or open a new post so you can get solution for this Joomla Tag error .puntje Friendpuntje
- April 2014
July 5, 2015 at 2:21 pm #576367no it 3.4.1. And if i update, i cannot save an article, so i put mine backup back.
How do i change step by step it in phpmyadmin
I must place this somewhere. I did. in the cs4zr_contentitem_tag_map but it does not work. I get a error message
INSERT INTO `#__tags` (`id`, `parent_id`, `lft`, `rgt`, `level`, `path`, `title`, `alias`, `note`, `description`, `published`, `checked_out`, `checked_out_time`, `access`, `params`, `metadesc`, `metakey`, `metadata`, `created_user_id`, `created_time`,`created_by_alias`, `modified_user_id`, `modified_time`, `images`, `urls`, `hits`, `language`, `version`) VALUES
(1, 0, 0, 1, 0, ”, ‘ROOT’, ‘root’, ”, ”, 1, 0, ‘0000-00-00 00:00:00’, 1, ‘{}’, ”, ”, ”, ”, ‘2011-01-01 00:00:01’,”, 0, ‘0000-00-00 00:00:00’, ”, ”, 0, ‘*’, 1);How much i replace. Mabye you can write it, step by step
I tryed to repair the database it, but that did not work
How can i change. I put 4 attachment below. Also with the error
So you can see the phpmydirectadmin- puntje Friend
puntje
- April 2014
July 5, 2015 at 2:21 pm #642688no it 3.4.1. And if i update, i cannot save an article, so i put mine backup back.
So you can see the phpmydirectadminpuntje Friendpuntje
- April 2014
July 5, 2015 at 2:21 pm #741345no it 3.4.1. And if i update, i cannot save an article, so i put mine backup back.
So you can see the phpmydirectadminjooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
July 6, 2015 at 12:44 am #576375Hi there
Please try with this one
http://forum.joomla.org/viewtopic.php?f=710&t=800583
Thank you,
Viet Vujooservices Friendjooservices
- October 2014
July 6, 2015 at 12:44 am #642696Hi there
Thank you,
- October 2014
July 6, 2015 at 12:44 am #741353Hi there
Thank you,
Viet Vupuntje Friendpuntje
- April 2014
July 6, 2015 at 1:18 am #576377Tried it. Does not work.
puntje Friendpuntje
- April 2014
July 6, 2015 at 1:18 am #642698Tried it. Does not work.
puntje Friendpuntje
- April 2014
July 6, 2015 at 1:18 am #741355Tried it. Does not work.
July 6, 2015 at 3:05 am #576397<em>@puntje 481408 wrote:</em><blockquote>Tried it. Does not work.</blockquote>
If the solution does not work i suggest you to post the issue on Joomla Forum , As its the problem in Core Joomla Tag component .I hope u will get a reply from there once u post it on Joomla Forum.Pankaj Sharma ModeratorPankaj Sharma
July 6, 2015 at 3:05 am #642713<em>@puntje 481408 wrote:</em><blockquote>Tried it. Does not work.</blockquote>
If the solution does not work i suggest you to post the issue on Joomla Forum , As its the problem in Core Joomla Tag component .I hope u will get a reply from there once u post it on Joomla Forum.AuthorPostsThis topic contains 28 replies, has 3 voices, and was last updated by jooservices 9 years, 3 months ago.
