questbg Friend
questbg
- May 2008
- 339 times in 197 posts
September 5, 2008 at 10:41 am #268922HI Hainn84
<em>@hainn84 77861 wrote:</em><blockquote>Hi questbg !
where do you download Joomfish – Content Table Localisation plugin ? </blockquote>This is a plugin for ‘Club Members’ only. I will ask JoomFish developers if I can send this to your, or if they can send it to you directly!
Thanks for the continued support.
Chrisquestbg Friendquestbg
- May 2008
September 5, 2008 at 1:10 pm #268933Hi Hainn84
I spoke with JoomFish and they are happy for me to send the plugin to you. I’ll send the .zip file by e-mail now.
Good luck!
- May 2008
September 7, 2008 at 5:18 am #269171Hi Hung/hainn84
Please could you mark this topic as ‘solved’.
The JoomFish developers came into the site and modified some code. It works fine now.
Thanks for all your assistance.
Chrisfresco Friendfresco
- July 2008
September 7, 2008 at 7:49 am #269183could you please tell us where to find the alterations they did?
I am going to use joomfish and that plug-in…Sherlock FriendSherlock
- 2478 times in 2162 posts
September 8, 2008 at 3:24 am #269272Hi questbg !
ok , i will mark this thread to “solved”. Please share that plugin to JA member via this thread. i think it very helpful. 😀 . thanks you.Sherlock FriendSherlock
September 8, 2008 at 3:24 am #269273Hi questbg !
ok , i will mark this thread to “solved”. Please share that plugin to JA member via this thread. i think it very helpful. 😀 . thanks you.questbg Friendquestbg
- May 2008
September 8, 2008 at 4:25 am #269299<em>@fresco 78222 wrote:</em><blockquote>could you please tell us where to find the alterations they did?
I am going to use joomfish and that plug-in…</blockquote>Hi Fresco
To be honest, I haven’t got a clue what alterations they did! One of the four core JoomFish developers (Geraint) asked me for SuperAdmin access and a couple of hours later it was working!
No worries though, if you go ahead with JA Telline II, JoomFish and the plugin, they will know the fix now!!
<em>@hainn84 78340 wrote:</em><blockquote>ok , i will mark this thread to “solved”.
</blockquote>Hi hainn84
Yes please mark to solved and many thanks for all your assistance.
Chris
fresco Friendfresco
- July 2008
September 8, 2008 at 8:07 am #269436thanks chris, but what’s bugging me is that probably I will have to pay for a work already done…
wouldn’t you send me your files, in order to make a diff and check what’s new? -
This topic contains 23 replies, has 4 voices, and was last updated by fresco 16 years, 4 months ago.
