Viewing 15 posts - 1 through 15 (of 18 total)
  • markskews Friend
    #170094
    I recently upgraded from J!1.6.5 to J!1.7.2 and see that using Teline IV for 1.7 my module titles don’t show in the col-mass-top position. No titles for any of the modules I have in the col-mass-top shows position.
    Is there some way to get the titles to show?
    Mark
    Usr: Skews, pwd: Edison32
    jooservices Friend
    #421807
    Could you please provide us your site url ?
    Viet Vu,
    markskews Friend
    #421818
    Hi Viet Vu,
    the URL is http://www.tutkamedia.fi
    Let me know if you require anything else.
    Mark
    jooservices Friend
    #421821
    It looks like your site is turning to maintenance mode so I could not check the issue on your site.
    Could you please provide the backend access , please fill it into the private place by editing your first post.
    Thanks.
    markskews Friend
    #421850
    <em>@jooservices 279013 wrote:</em><blockquote>Hi,
    Thanks.</blockquote>
    As per your request: in the first post
    Skews, Edison32
    Mark
    chavan Friend
    #421854
    Hope nothing to do with the Admin panel.
    I prefer you need to post your ftp details too.
    Note: If you Find my Post useful please click on the Thanks Icon
    markskews Friend
    #421859
    ftptutkadmin@tutkamedia.fi
    usr: ftptutkadmin
    pwd: kz4fU?y%-Q@9
    chavan Friend
    #421863
    Ftp is Not working…. Please try checking it and confirm.
    markskews Friend
    #421868
    I’ve checked and these settings work.
    server http://ftp.tutkamedia.fi
    kz4fU?y%-Q@9
    Mark
    chavan Friend
    #421873
    check your site. I have made it work. Please check it and confirm.
    markskews Friend
    #421879
    I notice that some of the modules in col-mass-top have their titles showing but not all of them. There is a ARI Pretty Photo module in the col-mass-top position whose title does not show.
    Something else I see is that the way of showing each module in col-mass-top position no longer seems to have a clear way tell each module apart from the other. Like a line between or something similar.
    Mark
    chavan Friend
    #421887
    sorry can’t understand…
    markskews Friend
    #421890
    I have a module in the col-mass-top position where the title is set to display, but it does not. The only difference with this module is that it is a ARI PrettyPhoto module and not a Custom HTML module.
    I also used to have a line between each module in the col-mass-top position. Since my upgrade to J!1.7.2 this is now gone. Is there an easy way to get it back?
    chavan Friend
    #421896
    Try adding the other module title and don’t go and hard code the css as an element html.
    Please post the css changes in the concerned css files.
    If you don’t have any effect, Please revert.
    markskews Friend
    #421944
    Hi Viet Vu,
    I now see that all the fixes that you’ve put into place earlier in col-mass-top are all gone. None of the titles are displaying at all. Please can we fix the problem as soon as possible?
    Regards,
    Mark Skews
This topic contains 18 replies, has 3 voices, and was last updated by  jooservices 13 years, 2 months ago.
