Netburn Friend
Netburn
- January 2006
May 23, 2016 at 7:06 am #933591Hello Guys,
Your Teline V template has a bug: It is not showing the Article Index or Table of Contents (Pagebreak plugin) when an article has multiple pages. I already tested with the last version of Teline V (1.0.8) and the quickstart template and it is definitely not working.
Also tested default Joomla templates and they are working fine and showing the TOC.
Here you can see the article where the TOC should be displayed:
http://www.aviacol.net/interes-general/es-seguro-viajar-en-avion-miedo-a-volar.html
I really appreciate your help on this regard.
Thank you.
Saguaros ModeratorSaguaros
May 24, 2016 at 4:44 am #934007Hi
The above link is not accessible now, could you update again and also Admin login info so I can have a look?
Netburn FriendNetburn
- January 2006
May 24, 2016 at 5:10 am #934008This reply has been marked as private.Saguaros ModeratorSaguaros
May 24, 2016 at 7:37 am #934028This reply has been marked as private.Netburn FriendNetburn
- January 2006
May 24, 2016 at 6:13 pm #934265This reply has been marked as private.Saguaros ModeratorSaguaros
May 25, 2016 at 10:33 am #934585I still can’t access your site, kindly check again.
- January 2006
May 25, 2016 at 2:43 pm #934675This reply has been marked as private.Netburn FriendNetburn
- January 2006
May 26, 2016 at 6:12 pm #935100Hello,
We’re waiting for a fix for this. We really need to show the Table of Contents in our multipage articles.
Thank you.
- January 2006
May 29, 2016 at 10:08 pm #935745Hello,
Please, it’s been almost a week. We need a solution.
Thanks.
May 30, 2016 at 7:59 am #935922It seems to be an issue of template, I’ve reported to the team for further checking, you can check its status here: http://pm.joomlart.com/browse/JATELINEV-347
- January 2006
June 3, 2016 at 7:27 pm #937644That’s what I told you on the first place. I checked and made sure it was a template problem before opening this ticket.
Do you have any estimate date for this to be fixed?
Thanks.
This topic contains 11 replies, has 2 voices, and was last updated by Saguaros 8 years, 3 months ago.
