  • ramiz padashi-fard Friend
    #159967
    Hi, the contact display Heading reads:
    # Name Position COM_CONTACT_CONTACT_EMAIL_ADDRESS Phone Mobile Fax Suburb State Country
    How can I get the heading to display correctly rather than com_contact_contact_email_address
    Ninja Lead Moderator
    #376006
    to avoid confusion, please upload a screenshot of this error page, but first, you should try to download and update the latest version of teline iii for 1.6
    #376030
    Thanks, I did that, it is solved. but on installing com_jaextmanager I get this error, is it not compatible with telineiii, it was not included either.
    * JFolder: :files: Path is not a folder. Path: D:wampwwwTelineIIIadministratorcomponentscom_jupgrade
    * JFolder: :files: Path is not a folder. Path: D:wampwwwTelineIIIcomponentscom_jupgrade
    Best Regards
    #376156
    dear ramizp, it appears to be a bug of com_jaextmanager, I will have our devs investigate it and have proper fix, you can track the progress here:
    http://pm.joomlart.com/browse/JAECCOMJAEXTMANAGERJIVI-21
    #376393
    I found the following error in displaying the contact list could this cause the error I posted initialy?
    **Untranslated Strings**
    # D:wampwwwtelineiiipluginssystemjat3jat3corejoomlaview.php
    COM_CONTACT_CONTACT_EMAIL_ADDRESS=”CONTACT CONTACT EMAIL ADDRESS”
    # D:wampwwwtelineiiipluginssystemjat3jat3coretemplate.php
    LAST_UPDATE=”update”
    RESET_USER_SETTING=”user setting”
    SKIP_TO_CONTENT=”to content”
    #376539
    screenshot please, along with the link of error page, even if its on localhost, that would help me address this bug.
This topic contains 6 replies, has 2 voices, and was last updated by  Ninja Lead 13 years, 11 months ago.
