  • chhaviwebnxt Friend
    #133514
    Template is not uploaded…got error Installation file not found: and Unrecoverable error “PCLZIP_ERR_BAD_FORMAT (-10)….
    bennitos Friend
    #271361
    Hmmm can you try if the zip file is working and is not corrupted?
    Try to unpack it on your pc first.
    #271448
    Hi chhaviwebnxt
    Do you have any success ?
    chhaviwebnxt Friend
    #271469
    yes i did unpack it on my pc…
    #271831
    can i mark this topic is solved ?
    Menalto Friend
    #272892
    I close it and if tread starter needs further help he/she can start a new post.
This topic contains 6 replies, has 4 voices, and was last updated by  Menalto 16 years, 3 months ago.
