  • hobbyfun Friend
    #144612
    Dear all,
    I just installed Pyrite, and I’d like to add another template to my site, but there is an error message appear,
    1.
    Warning, fail to move file.
    Unable to find install package
    2.
    I’m using Internet Explorer, when I tried to upload an image and clike on the button, nothing happend. please help me to resolve these problem out. Thank you. please find my login detail as mentioned below.
    Anonymous Moderator
    #318665
    Hi hobbyfun
    I have checked your website and saw that you solved this issue.
    Please feel free to contact us if you are in need of further assistance.
    Arvind Chauhan Moderator
    #318667
    Dear hobbyfun,
    Do not provide your site login info in open.
    Do not make duplicate threads for the same problem. Your earlier thread with the same problem has been deleted.
    Arvind
    hobbyfun Friend
    #318678
    <em>@JA Developer 146381 wrote:</em><blockquote>Hi hobbyfun
    Please feel free to contact us if you are in need of further assistance.</blockquote>
    Thank you for your quick reply. But the problem is still there. Nothing resolved. Pyrite template was installed by quick start package. I’d like to add another template, but when I click on the upload and install button, the error message appears.
    and image upload interface doesn’t work under IE under Media manager.
    Could please help me to solve this problem. Thanks a lot.
    Hobbyrun
    hobbyfun Friend
    #318679
    <em>@drarvindc 146383 wrote:</em><blockquote>Dear hobbyfun,
    Arvind</blockquote>
    Hi Arvind,
    Thank you for your advice, I’m new here. When I asked for help, I saw there is something like formula that I need to fill up with my login in order to get help from the others. So I did it.
    This problem makes me a big headack since several days.
    #318688
    Hi hobbyfun,
    Which another template you wish to install? I shall give it a try.
    When you add your site info…. make sure you add it in the “require Help from Mod / Admin” box only… do not include your login details into the posts.
    Arvind
    hobbyfun Friend
    #318692
    Hi Arvind,
    I’m tring to add Raite template.
    #318697
    Thread closed, as a new thread has been started by the Thread Owner. This thread shall be deleted in the next 24 hours.
    Arvind
This topic contains 8 replies, has 3 voices, and was last updated by  Arvind Chauhan 15 years, 3 months ago.
